How To Scew Into Stone Foundation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-09-2010, 11:13 AM   #1
How to scew into stone foundation?
How do I screw into stone foundation?
Kacavich is offline   Reply With Quote
Old 09-09-2010, 11:45 AM   #2
Rewards Points: 79
Knowing the purpose of this screwing would be helpful. As well, the type and age of the stone and mortar would help too. But - at it's face, one answer is to use lags and shields. There are direct drive screws that have a few different names. Then there are bolts. I don't know how familiar you are with fasteners nor what tools you have at your disposal but you will most certainly need a drill - and possibly an impact drill depending on what you're trying to do. The type of stone- even if you aren't sure of the exact name - a picture or description such as - greyish blue and will flake if struck for instance. That might be shale. But if its maroon and seems harder than anything you can imagine, well thats one I've run into myself and don't know the name, but I ended up buying a diamond bit after wearing out my carbides. Anyhow - please try to answer a few of these questions and we'll be glad to help you out. I've worked on alot of old homes and probably drilled into stone foundations about 20 or more times and each one poses its own special character - for lack of a better word.
If you don't have time to do it right, when will you ever have time to do it over?
jackofmany is offline   Reply With Quote
Old 09-09-2010, 06:13 PM   #3
Knucklez's Avatar
Rewards Points: 942
i had a similar question a while back. my foundation is also stone (round white and hard hard hard!). i was thinking.. how am i going to attach my deck to this? i asked around and all the suggestions i got were to NOT attach at all and build a floating deck. glad i did.
so my point is, maybe there is an easier way. what are you trying to do?
Knucklez
"if you can't be handsome, at least you can be handy" -Redgreen
Knucklez is offline   Reply With Quote
Old 09-10-2010, 07:45 AM   #4
Rewards Points: 79
Seems the most important piece of this puzzle is still missing. What are you trying to accomplish? It is very difficult to give an answer without this info. Not to mention the other stuff that was requested.
Old 09-10-2010, 08:29 AM   #5
Rewards Points: 558
By using a hammer drill or a core drill.
epson is offline   Reply With Quote
Old 09-22-2013, 07:11 PM   #6
Stone foundation
MY FOUNDATION ( House built 1900) Is stone with morter. I would like to attach 2"X 4" boards to basement walls then I could hang peg board and hang stuff from the walls. The foundation rocks are grey with really old morter.
What type of screws ??? do I use?
Thank you,
Shelley
SHELLEYVOGT is offline   Reply With Quote
Old 09-22-2013, 08:17 PM   #7
Haverhill Trade 1965
You should also describe the size of the rocks. you risk splitting them with expansion type anchors. how flat and uniform is the surface? Is the weight supported by a floor, footings, or by the bolts?
Duckweather is offline   Reply With Quote
Old 09-22-2013, 11:48 PM   #8
GBrackins's Avatar
Rewards Points: 2,108
have you considered hanging your peg boards with lumber attached to the floor joists instead of trying to attach to the stone?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following User Says Thank You to GBrackins For This Useful Post:
Duckweather (09-23-2013)
Stone Foundation with large gaps and cracks Knucklez Concrete, Stone & Masonry 18 04-07-2016 11:34 AM
crumbling field stone sandstone foundation...can we resurface the visible outside portion? btolt162 Building & Construction 2 07-06-2010 12:04 AM
Pointing a stone foundation bilbobroberts Building & Construction 2 07-19-2009 10:50 AM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 01:49 PM
