How To (safely) A Cut A Ceiling Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-13-2013, 11:47 AM   #1
Special User
Rewards Points: 1,230
How to (safely) a cut a ceiling joist
I have a 1971 single-story ranch house with a hip roof. Last fall, when I had it re-roofed, I had the roofers install a 20"x20" roof jack for a downdraft swamp cooler. It's in the middle of a 24" O.C. rafter bay.
Below the cooler, I have 16" O.C. ceiling joists, and of course one of those joists is directly below the swamp cooler so it will need to be cut to allow the duct to come down.
I know it's odd, but there is no truss in this area (near a hip). My HVAC guy who will be doing the ducting recommends just cutting a 20" section out of the offending ceiling joist, but I think it needs reinforcement. Should I simply head off the cut joist by installing perpendicular blocking between the neighboring joists, or should I run two new joists 24" O.C adjacent to the duct opening and parallel to the existing joists?
Also, do I dare use a recip saw to cut the joist? Since this is 1971 construction, the drywall ceiling might be nailed up instead of screwed, and I'd hate to pop nail heads all over my ceiling or crack a taped seam (some of the taped seams are already iffy)...
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 03-13-2013, 05:25 PM   #2
Dave Sal's Avatar
Rewards Points: 566
When I installed a skylight back in the early 80's I had to cut a ceiling rafter. I reinforced the cut end with blocking as you described. It's been fine ever since.
Dave Sal is offline   Reply With Quote
Old 03-13-2013, 05:31 PM   #3
Rewards Points: 12,794
Lay two 2 X 4's laying flat out of the way of the area being cut and screw them to the joist before cutting.
I'd use a ciruler saw set at max depth to make the first cuts and finish with an ossilating saw for less stress on the ceiling.
tylernt (04-16-2013)
Old 03-14-2013, 10:10 AM   #4
Special User
I take it that's to keep the cut joist from sagging while the blocking is being installed?
Old 03-16-2013, 03:34 AM   #5
An old Tradesmen
Rewards Points: 6,072
Moved to Building and Construction forum.
Old 03-16-2013, 11:40 PM   #6
Registered User
Rewards Points: 4,894
http://publicecodes.cyberregs.com/ic...9_8_par034.htm
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 03-16-2013, 11:55 PM   #7
Special User
Thanks Gary. Now that I know the correct terminology (header, trimmer) I can search for examples. I believe the code is pretty clear but pictures can only help.
Old 04-16-2013, 10:06 AM   #8
Special User
I ended up just using an oscillating saw for everything, didn't take too long to buzz through the joist in two spots. Used Simpson Strong Drive Screws (code-approved to replace nails) to avoid swinging a hammer. Didn't pop any drywall nails (and they did turn out to be nails) in the ceiling below nor crack any seams.
http://lh4.ggpht.com/-8iv6vU5tgFI/UW.../IMG_2422.jpeg
Thanks guys!
The Following User Says Thank You to tylernt For This Useful Post:
Gary in WA (04-16-2013)
Opening Ceiling Joist for Recessed Light DAKRO Building & Construction 14 01-01-2012 01:21 AM
Bad news - asbestos and a failing ceiling joist system sheslostcontrol General DIY Discussions 17 05-30-2011 12:34 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
Rotten ceiling joist, top & cap plate and studs chuckball Carpentry 3 04-24-2008 11:57 AM
Ceiling Joist Worries clayrabbit Building & Construction 11 01-06-2008 06:07 PM
