How Safe To Dig Near Concrete Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-07-2009, 05:02 AM   #1
how safe to dig near concrete slab
the slab has buried radiant heating elements for our garage. The winters are as cold as -30 degrees F in northern Maine. I am going to install a below ground ( about 15 inches) composting pit with a wood door to keep away critters. the ground does freeze in winter down to about 4 feet in bad snow years. We do not want to mess up the heated garage or the foundation. How closely can I dig to the concrete slab? thank, roberta
Roberta-mos is offline   Reply With Quote
Old 06-07-2009, 06:45 AM   #2
I assume the garage floor is insulated, not that it matters. I doubt the heat from a compost pile will have much affect on the garage floor or foundation. My concern would be from water in the pit.
Old 06-07-2009, 05:48 PM   #3
Rewards Points: 5,336
The radiant elements are in the slab and should be away from the edge. Your digging outside the garage should have no connection with the heating elements.
Ron
Old 06-07-2009, 06:23 PM   #4
Your garage floor will very likely be supported underneath with a foundation. This will rest on a footing that is 4' down.
Your excavation is highly unlikely to have any effect on the garage floor.
As you dig your pit, you will likely see the foundation wall.
Old 06-09-2009, 07:06 AM   #5
thanks for your replies
The pit is dug. Only problem is that it is not big enough to get through our long winter for a collection of compost. I might need to dig another! roberta.
Old 06-09-2009, 09:26 AM   #6
Rewards Points: 1,910
Seems like a bad idea to have a compost pile/pit in close proximity to the house. Vermin and rot are not things to attract to the house.
Old 06-10-2009, 04:58 AM   #7
the garage is detached, the pit on the far side of the garage from the house. There is no meat in my compost. The only thing to fear is bears.....yes bears. They eat anything. and they can get into anything they want. We live in the woods in northern Maine. We have a large dog. So far...no termites this far north, just carpenter ants ...we already have those. mostly compost smells and has various flies. this plan has a vent pipe with a screen for fly contro.l the worms are a helpful hopeful guests.
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 06:25 PM
Cork or engineered wood over concrete slab w/ Radiant heat, HELP! newdyier Flooring 9 11-04-2008 04:11 PM
Extending Concrete Patio Slab bobo Building & Construction 6 04-17-2008 12:17 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
Concrete slab weeps moisture dale h Flooring 2 04-30-2005 10:29 AM
