How To Resolve A Foundation Issue Inexpensively? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-04-2008, 10:45 PM   #1
Question
How to resolve a foundation issue inexpensively?
I recently found out that my 2-level home is built on 24 inch centers as oppose to 16 inch. As a result, I am noticing a few cracks in the wall, in addition to a slight decline of the floor in the foyer area. Also several closet doors are not closing properly and the front door (glass) tends to stick. I did call around to a couple of foundation repair companies and the estimates I was given were all over $6000. Is there any other way I can get this issue resolve cheaper.
wrmbmm is offline   Reply With Quote
Old 06-04-2008, 11:02 PM   #2
Rewards Points: 1,232
Sure. Use some toothpaste to hide the cracks and sell.
Tscarborough is offline   Reply With Quote
Old 06-05-2008, 09:14 AM   #3
Registered User
Termite's Avatar
I don't understand the question. Are your problems related to the 24"oc stud spacing or are they related to the foundation settling? Or, are you talking about 24"oc rebar placement in the foundation?
If doors are sticking, I'd tend to attribute that to foundation settlement issues, not stud spacing.
There's no such thing as inexpensive foundation repairs, unfortunately. Piering, tiebacks, etc....They all cost a few thousand or more.
Tags
16 inches , 24 inches
Re-grading around foundation? robertr4836 Landscaping & Lawn Care 10 05-23-2009 06:34 PM
Floor Joists Lifting Off Foundation Walls?! cbeingessner Building & Construction 2 06-12-2008 09:39 AM
concrete foundation with a crawl space agrenvik Building & Construction 1 03-25-2008 09:27 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 10:36 AM
Stone foundation for a small shack andrgo Building & Construction 10 09-13-2007 02:49 PM
