How To Replace Water Damaged Outside Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-18-2009, 08:53 AM   #1
Unhappy
How to Replace water damaged outside wall
My husband and I pulled up old carpeting and found water damaged plywood in front of the sliding glass doors. After pulling out the plywood to replace we found rotted wood under the sliding glass door so bad that we can see and feel the tyvac paper and siding. What do we do now?
cmnuzzo is offline   Reply With Quote
Old 09-18-2009, 11:58 AM   #2
Rewards Points: 5,332
You will remove the door and the siding under and around the door(as needed). Replace the damaged structure and reinstall the door and siding properly,as one or both were not done so originally.
Ron
Tags
outside wall , rotting , water damage
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 12:23 PM
Wall unit AC drips water inside fw2007 HVAC 4 08-15-2008 10:07 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
