How To Replace Posts Before Concrete Is Poured - Building & Construction - DIY Chatroom Home Improvement Forum
View Poll Results: Is post clearly written and asks straight forward question
THe situation has been explained well and question is clearly asked. 2 66.67%
little unclear on the situation 1 33.33%
little unclear on the question 0 0%
Voters: 3. This poll is closed
Old 05-05-2010, 02:42 PM   #1
Rewards Points: 150
Question
How to replace posts before concrete is poured
the picture should explain everything. the four posts are holding up a porch.
when i pour the concrete it will crack out from the four corners of the rotting posts. so replacing the posts before the concrete is poured will still result in cracks from the new inlaid posts.
HOW DO I SUPPORT THE PORCH, GET RID OF THE ROTTEN POSTS AND LAY CONCRETE?
i have a manual post hole digger and don't want to spend lots of money on round steel posts.
rosco is offline   Reply With Quote
Old 05-05-2010, 03:05 PM   #2
Rewards Points: 150
another pic
here is picture from a different view:
Old 05-05-2010, 03:52 PM   #3
kwikfishron's Avatar
Rewards Points: 1,002
A picture of what the post are holding up would help but basically you need to temp. up the porch to the outside of your pour.
kwikfishron is online now   Reply With Quote
Old 05-05-2010, 04:19 PM   #4
Concrete & Masonry
Rewards Points: 636
I would replace the posts first if it was my own. I would also wrap the bottoms (below top of concrete) with I&W sheild & wrap 1 layer of foam expansion joint around the post to allow the concrete to move independently w/o binding. For the 2 posts in the middle of the pour, I would run a control joint right to the center of them. The 2 outer posts should be fine with just the expansion around them.
jomama45 is offline   Reply With Quote
Old 05-05-2010, 04:40 PM   #5
Why not post brackets?
Old 05-05-2010, 04:50 PM   #6
Concrete & Masonry
Rewards Points: 636
Mostly because there is no mention to where in the world this may be.
If the patio were ever to heave, it would take the deck with it.
Post brackets would work IMO, but here's how I would do it then:
Extend the existing sonotubes to or above the top of the new patio elevation with tubes. Dowel a few small rebar chunks into existing sonos.
Wrap teh new tubes with the same expansion material. Fill inside of tube the same time as pouring patio. Set post anchors after concrete is hard.
Old 05-05-2010, 07:01 PM   #7
I totally agree. If heave is a issue then dig, Anything than
entombing the post in mud.
Old 05-05-2010, 07:06 PM   #8
i agree with all of this with the one question of whats under those posts now. footing?
The older I get the better I was
Old 05-05-2010, 07:10 PM   #9
I'll bet a 100 on nothing.
Old 05-05-2010, 07:16 PM   #10
looks like concrete in the one pic unless its old slab
Old 05-05-2010, 08:19 PM   #11
Rewards Points: 150
hmmm
Extend the existing sonotubes to or above the top of the new patio elevation with tubes. ...
Wr....erial. Fill inside of tube the same time as pouring patio. Set post anchors after concrete is hard.
if the patio heaves it will take the porch with it? there is slight movement in the soil or settling, but no earthquakes.
i'm curious if i could wrap this tape around the existing 4x4' and pour the concrete mix. once poured, i'd bracket in the old 4x4's. it seems unlikely that i could prop this porch up. it is a "home job" from about 30 years ago. and we have little interest in putting $ into it.
Old 05-05-2010, 08:31 PM   #12
Rewards Points: 150
contrete footing at bottom of posts. these posts were in dirt before i dug them out and broke off top three inches to lay cconrete (someone told me that was a good idea.
i've no idea how much is below it but i'll bet about 6" from just the way one of the post's foot was broken. it wiggled like a broken tooth.
is there a way i could treat or fill in the rotten portion so it doesn't rot more? and then a way to wrap expansion tape around it to prevent thin cracks to from going out from the posts as the concrete slab is poured?
who did you bet? i'll take the payout on that bet to fund this project!
Old 05-05-2010, 10:27 PM   #13
Concrete & Masonry
Rewards Points: 636
Somehow, I caught that little part in the pic as well. I usually don't look at these pics long enough to catch these kind of things, but it looks like some kind of sonotube ot me.
i'm curious if i could wrap this tape around the existing 4x4' and pour the cement. once poured, i'd bracket in the old 4x4's. it seems unlikely that i could prop this porch up. it is a "home job" from about 30 years ago. and we have little interest in putting $ into it.
No big suprise!
Yes, the patio could heave IF you are in a cold climate, but I guess no one here will ever know if that's the case.
You can wrap the existing posts, but if they touch any earth or concrete, they will continue to wick moisture into themselves & rot out. Now would be a good oppurtunity to rectify that situation.
Old 05-05-2010, 10:52 PM   #14
cocobolo's Avatar
Rewards Points: 6,114
We are lacking some information here. It might be very handy to know what these posts are holding up, and what the weight may be.
In any event, I think you might be barking up the wrong tree here. Don't entomb your posts in your new pour.
Take the weight off the posts, one at a time if necessary, dig a hole and construct a proper footing under the location of the posts. If you could make the top of your footing slightly above the finished concrete floor - about 3 or 4 inches, that would be good. You could set your saddle in the correct place and the problem of future rotting wood is solved.
If there is some old concrete under there, I would get it out.
cocobolo is offline   Reply With Quote
Old 05-05-2010, 11:26 PM   #15
Rewards Points: 150
What are you talking about? read two or three replies above the last jomama45 reply and you'll see i wrote the posts have concrete feet. i don't know how deep they are. i'll guess 6".
"barking up the wrong tree"? do you mean that i have the wrong approach or that i'm asking the wrong people?
jomama45 - the owner of the house, not me, is wanting to save money and knows these posts are rotting. she can see them. if i could wrap it in expansion tape there wouldn't be cracks shooting off around the posts. the posts would be bracketed to the concrete so when they do rot, she should be able to see more of it before the porch collapses. are you kinda following me? it is likely i won't be here to catch blame for not putting in steel poles and replacing much of the rotting wood above in the actual porch. someone else will get to deal with that.
Tags
concrete patio wood post
Insulating poured concrete basement walls Dude Building & Construction 0 03-03-2010 12:24 PM
Blocks or poured concrete for round tower? silverfrost1 Building & Construction 7 07-13-2007 09:27 PM
Math check on amount of concrete for poured foundation? Badfish740 Building & Construction 10 05-05-2007 06:49 AM
Framing 2 concrete posts in middle of basement yummy mummy Building & Construction 20 01-16-2007 02:14 PM
Installation of pergola posts HDelahay Landscaping & Lawn Care 13 10-11-2006 06:46 AM
