Old 11-22-2011, 07:57 PM   #1
How to replace joist bridging for HVAC ducting?
Hi all,
I want to re-route the hvac ducting in my basement into the joists above to increase ceiling height. Right now, it has cross style joist bridging, so can I just replace it as shown in Figure 4 here, http://www.renovation-headquarters.c...20bridging.htm ?
If so, how much depth (the dimension into the screen) do I need? Would it help to cut a hole into a solid bridge to reinforce it? And, can the ducting rest on the wood, or will I need to support it by hanging just above?
Thanks.
bull4uw is offline   Reply With Quote
Tags
hvac, joist bridging
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 03:18 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 02:07 PM
How to repair floor joist when sistering is not an option jmagee3d General Discussion 2 06-05-2009 03:33 PM
replace floor joist edward r Carpentry 4 02-03-2009 08:06 AM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
