How To Repair Concrete In Front Of Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 02:50 PM   #1
Busy DIYer
picflight's Avatar
Rewards Points: 150
Question
How to repair concrete in front of garage
How do I begin repairing this?
At some point there was a tree, the roots raised the concrete and cracked it. The triangle piece is now a bit wobbly as I tried to dig underneath and press down in an effort to level it. The asphalt part is also raised, that has to be leveled too.
I have never done a repair like this before.
My thoughts are to break the triangle piece into small pieces, put a form around and fill with concrete mix. Do the same for the asphalt part, except I don't know what is the fill, and top layer would be for the asphalt section.
Or, somehow align the heavy triangle as best as I can and patch the crack. But if the base is not level and some settling would crack it again.
picflight is offline   Reply With Quote
Old 10-28-2011, 04:17 PM   #2
concrete contractor
Break up the triangle and remove it or, if it settles into the ground enough that you can cover it with 3-4 inches of new concrete, leave the broken up pieces in place as fill. Drill into the side of the remaining section of concrete and hammer in some rebar. Then form, mix and add some new concrete. As for the asphalt, you can get some cold patch at home improvements centers that might work.
johnnyconcrete is offline   Reply With Quote
Old 10-28-2011, 04:27 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 666
Send a message via Skype™ to AndyGump
If you want it to look good, saw cut the entire section of concrete out from in front of the garage then do as johnnyC. says.
Clean up the site, level out the ground, create new forms. drill the existing conc. with 5/8" holes about 24" O.C. (no epoxy) pour new conc. right on the ground about 4" thick.
Andy.
AndyGump is offline   Reply With Quote
Tags
driveway
Concrete Footings for a Detached Garage??? canyonbc Building & Construction 76 11-17-2016 10:23 AM
3" gap between concrete driveway and garage floor need to fill frankrizzo Building & Construction 0 11-23-2010 08:08 AM
Concrete reinforced block foundation repair questions CCHanna05 Building & Construction 2 07-06-2010 03:57 PM
Replacement concrete garage floor, dowelled into foundation? Niffumdutz Building & Construction 5 02-19-2010 08:31 PM
Basement Garage with Concrete Slab: To Vent or not to Vent N-GA-Homeowner Remodeling 3 05-29-2009 06:13 AM
