How To Repair Cement Block Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 05:02 PM   #1
How to repair cement block walls
A crawl space under part of my house has cement block walls on three sides. Many of the vertical mortar joints have cracked and are quite wide with deep voids behind them. Should I try to fill the voids and joints with mortar or fill the voids with something else first?
hc1974 is offline   Reply With Quote
Old 08-20-2011, 07:22 PM   #2
Rewards Points: 5,332
Post some photos. The issue could be simple or complex.
Ron
B. Franklin 1759
Old 08-20-2011, 07:30 PM   #3
Concrete blocks are designed with a void in the middle of the ends, of the block. When a block is laid, mortar is applied to the outer, corner edges only.
If you are going to repair the mortar, its only necessary to replace it where the blocks meet. The void in the center need not be filled.
FINISHING BASEMENT WALLS - Cinder Block Walls tmacwith Building & Construction 4 12-06-2012 08:26 AM
Basement cement block cover... abcad General DIY Discussions 1 03-01-2011 04:00 PM
Masonry Repair walls question tonydiato Building & Construction 0 03-18-2010 06:22 PM
2x4s on block walls Captflx Building & Construction 4 08-24-2009 08:25 PM
Best way to insulating a heated detached cement block garage Joe Nulph Building & Construction 1 03-06-2006 10:30 AM
