How To Remove A Section Of Vinyl Soffit Vent - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-26-2010, 07:14 PM   #1
Rewards Points: 640
how to remove a section of vinyl soffit vent
My front porch is basically under my roof and the ceiling of the porch is vinyl soffit venting about 5 ft wide panels of it... well the space above it I need to get into (its a fairly big space about 4 ft high on one end and 5 ft wide......) to fix an insulation problem on the far end of it.... how do I remove a section or two of that to get into the attic space? its installed like soffit vent normally is on the overhanging area of a roof..... just never had to remove it before.... thanks!
BlueBSH is offline   Reply With Quote
Old 06-26-2010, 07:50 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
look where the panel ends in the j channel,find where the panels lock together,take a screw driver,or ice pick at the panel end and''peel'' it away the entire length
that will expose the fasteners of the previous panel,remove as many as needed
Tom Struble is offline   Reply With Quote
Tags
soffit vent
Venting Bathroom Fan through Attic to soffit vent, vancouver island noonatak HVAC 2 05-12-2010 08:07 AM
Newbie: Soffit NFA calculation + what material for vent? Tranch Roofing/Siding 5 07-19-2009 05:43 PM
spacing soffit vent panels DangerMouse Building & Construction 2 10-29-2008 06:17 AM
Need to paint a vinyl gable vent: durability?? Aged1 Building & Construction 2 07-31-2008 09:10 AM
Another Ridge Vent, Gable vent and soffit question (??) davco Roofing/Siding 2 04-30-2007 11:14 PM
