How To Remove Musty Odor, Waterproofing A Cement Block - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-19-2008, 02:36 PM   #1
how to remove musty odor, waterproofing a cement block
i have musty odor in my basement. Anyone has any idea which product is best to remove that odor?
Also i would like to waterproof the cement block wall in this basement which is good, drylock, radeonseal,or sanitred/
i'll appreciate all reply.
handydady is offline   Reply With Quote
Old 09-19-2008, 02:53 PM   #2
Rewards Points: 1,088
Best way is to kill the mold with bleach/water combo, and then keep the humidity at 45% or lower. Also, circulate fresh air as much as possible.
Drylock is the big name in sealing cinderblock.
handy man88 is offline   Reply With Quote
Old 09-19-2008, 03:03 PM   #3
Custom Cabinet Maker
Moth balls or crystals
skymaster is offline   Reply With Quote
Old 09-19-2008, 03:40 PM   #4
concretemasonry's Avatar
Rewards Points: 2,640
handydady -
How many years was the basement musty and have moisture? - If a few years, it may be coming from the floors, and ceiling also by now. In any event, circulation, plus fresh air is required. Other things just substitute different smell for a while. - It is not a quick fix.
handy man -
Drylock is not that great on cinder block (if you can even find them in NY, NJ, PA and OH). It is better on concrete block, but nothing beats getting rid of the moisture from the ouside and the floor and under the floor.
concretemasonry is online now   Reply With Quote
Old 09-19-2008, 06:57 PM   #5
Originally Posted by concretemasonry View Post
handydady -
handy man -
Hmm, didn't know there was a difference between cinder block and concrete block.
I bought a can of drylock for a hairline crack on my poured concrete foundation. Is drylock not good for this application?
Old 09-19-2008, 07:19 PM   #6
Drylok is not intended for cracks. It is a surface coating, like paint.
Cinder block were made years ago using waste cinders from industrial operations burning coal. Because they were made from waste materials, they had varible properties, most of which were not good. They were used very well for some specific application. the block were cheap and readily available years ago in eastern industrial areas.
Concrete block are made from either normal (heavy) aggregate, lightweight aggregate or a blend of the two. Lightweight block cost more and insulate better. Both are made according to ASTM C90 standards.
Dick
Old 09-19-2008, 07:54 PM   #7
Dick
Drylock's ad, whether anyone believes or not, says that it penetrates into the crack.
BTW, what is usually done, if anything when there are hair line cracks in the slab?
How to install belgian block? Tmb9862 Building & Construction 2 09-19-2008 04:50 PM
laying 4x8x16 cement block.. top/botton ohpoppy Building & Construction 1 08-01-2008 08:33 AM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
Best way to insulating a heated detached cement block garage Joe Nulph Building & Construction 1 03-06-2006 10:30 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
