How To Remove Mold From Stone Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-29-2011, 02:40 PM   #1
KBS
Hello,
I have some black mold on my stone foundation in my basement.
I heard you can use bleach to get rid of it, is this the best technique?Thanks KBS
KBS is offline   Reply With Quote
Old 10-29-2011, 02:51 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
It's the least expensive that works.
There are other products that people would be anxious to sell to you but bleach works as well and in some cases better. The price is right.
The Following User Says Thank You to Bud Cline For This Useful Post:
KBS (10-31-2011)
Old 10-29-2011, 05:03 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 766
Ditto......
Take a spray bottle....pour about 4" (or 1/4) of bleach into it....fill it the rest of the way with water....spray on affected areas.....
Actually...a 10:1 solution would work fine....but I'm impatient.
We use a bottle with a 10:1 solution with some soap in it as well....works well for cleaning the tub/shower.
ddawg16 is online now   Reply With Quote
Old 10-29-2011, 08:30 PM   #4
Rewards Points: 5,336
Spraying chlorine bleach will require the proper respirator. Without it, you'll burn your sinuses.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
KBS (10-31-2011)
Old Stone Foundation Repair Nivk Building & Construction 21 02-12-2016 02:33 PM
Stone Foundation Woes dandelauro Building & Construction 6 09-25-2009 04:41 PM
what tool to rent to remove cultured stone tgseaver Tools 4 09-07-2009 09:09 PM
remove and re-use stone veneer Cecosugi Building & Construction 6 08-20-2009 11:08 PM
Concrobium or White Vinegar? eis61374 Remodeling 8 11-17-2008 07:56 AM
