How To Remove Joist Hangers - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-08-2010, 01:15 AM   #1
how to remove joist hangers
I'm in the process of sistering, however two of the joists are ones I made repairs ot a couple months ago (replaced header+installed joist hangers).
I guess I did a really good job, because I can't get the damn hanger off. The nails are flush with the hanger, and the nails that penetrate the joist itself is flush against the hole, and I can't get a claw to this either.
Does anyone know the best way to remove a joist hanger, without damaging the header and the joist? Thanks.
Tonglebeak is offline   Reply With Quote
Old 09-08-2010, 01:46 AM   #2
jlhaslip's Avatar
Rewards Points: 386
sawzall
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Old 09-08-2010, 06:52 AM   #3
Wonderbar/hammer, with a piece of shim to protect the wood.
Old 09-08-2010, 09:49 AM   #4
Rewards Points: 558
Well first you have to support the joist before you begin, then you can pull out the joist hanger. This is done not by tugging on the metal, but by pulling the nails out one at a time, until the end of the joist comes free from the box frame that supports it. Pulling large framing nails out of an attached joist is not a simple task, so you have to be patient and pull each nail, a little bit at a time.
First get yourself a flat metal pry bar slide the curved end behind the nail and slowly pull the head of the nail towards you until the whole nail comes free. Repeat this process with each nail until the joist hanger comes free with no effort.
That’s the long and short of it my friend…
epson is offline   Reply With Quote
Old 09-08-2010, 11:36 AM   #5
Registered User
Rewards Points: 4,902
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
Gary
Old 09-08-2010, 01:16 PM   #6
Rewards Points: 270
I did a couple of these in my crawl space - large hangers with 1-1/2" Simpson hanger nails - luckily only a couple of them to remove. Figured I'd write off the hanger and just get some leverage any way I could. In that case getting the bar under the metal and even close to a nail was enough to get 1 or 2 good tugs on the bar to pop the head just a tiny little bit (enough to tap another bar under it and pull it). Never thought I could mangle a joist hanger that badly (would have been a good item to send to one of those "can you guess what this is" contests) but I didn't care. Got them both out with surprisingly very little damage to the wood. Probably lucky - and not a fun job.
rtoni is offline   Reply With Quote
How to gently remove (aluminum) soffit? superfly Roofing/Siding 1 09-06-2009 10:15 PM
Joist Hangers handy man88 Building & Construction 1 10-28-2007 11:12 PM
Wider Joist Hangers BigJimmy Building & Construction 1 10-28-2007 11:08 PM
Simpson Joist Hangers NateHanson Building & Construction 5 10-02-2007 04:11 PM
Cutting/drilling hole in joist - How big? curls00 Carpentry 3 07-20-2007 10:56 PM
