How To Remove This Fastner? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-18-2014, 11:49 PM   #1
Rewards Points: 119
How to remove this fastner?
I need to take apart this pizza hood oven. I tried drilling through it with a standard black drill bit but was unsuccessful.
SpaceCoast is offline   Reply With Quote
Old 01-19-2014, 01:12 AM   #2
Rewards Points: 6,652
You mean those Rivets? A Drill Press will make quick work of them, along with a sharpened bit.
Old 01-19-2014, 02:54 AM   #3
get a metal bit sounds like you are using a wood bit either way you need a new bit
kennzz05 is offline   Reply With Quote
Old 01-19-2014, 05:38 AM   #4
Rewards Points: 13,714
Looks like you used to small a bit and only drilled out the center.
A slightly larger bit and do not try to go all the through.
Sort of wiggle the bit around as your drilling and it should catch enough to stop it from trying to turn.
Your trying to just cut off one side of the rivet head.
Old 01-19-2014, 08:54 AM   #5
AHH, SPANS!!!
Rewards Points: 1,166
I found an 1/8" drill bit works great for rivets. get a titanium gold bit for metal...
hand drive is offline   Reply With Quote
How do you remove a wood stove and bricks from living room? SimpleJack Remodeling 13 08-28-2011 01:26 PM
Wrong Sealant used on Unfinished Ceramic Tile... how to remove?! flipjarg Flooring 3 02-15-2010 09:09 PM
best way to remove areca palm root system Dus Landscaping & Lawn Care 0 01-23-2010 09:40 AM
Frigidaire/can't remove front water/ice dispenser tigerfan44 Appliances 0 12-17-2009 10:45 PM
How can I remove my gutter / apron with out pulling the first row of shingels wamyers92 Roofing/Siding 3 07-02-2008 02:10 AM
