How To Remove Cultured Marble Bathroom Vanity Countertop - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-04-2011, 10:50 AM   #1
Rewards Points: 55
How to remove cultured marble bathroom vanity countertop
I will be replacing my existing cultured marble bathroom vanity countertop with a new cultured marble countertop. I am not replacing the vanity; it is brand new. So first I need to remove the existing countertop without damaging any of the vanity wood. The countertop is not screwed into the vanity. Instead there is a bead of adhesive between the countertop and the vanity, and there is a silicone caulk bead between the edge of the vanity and the tile on the wall.
I assume I can use a utility knife to cut the silicone caulk at the edge of the vanity.
But how do I loosen the adhesive between the vanity so that I can lift off the old countertop, and do this without damaging the vanity wood? What tools and techniques do I use?
goshenplumber is offline   Reply With Quote
Old 03-04-2011, 02:15 PM   #2
Rewards Points: 1,522
same way, unless they used construction adhesive and then it may be difficult. Might be able to use a hacksaw blade to saw through the adhesive between top and vanity base if razor knife won't work.
bob22 is online now   Reply With Quote
Old 03-04-2011, 02:26 PM   #3
Rewards Points: 5,336
You might try a stiff scraper, maybe 1"-2" wide. Sort of like a taping knife, but more ridgid. Get it between the top and vanity and tap it along with a hammer.
Don't use a construction adhesive for the new top. Silicone caulk is more then enough to hold it in place.
Ron
Old 03-04-2011, 05:36 PM   #4
Household Handyman
Rewards Points: 1,408
Done a couple of these with what appeared to be construction adhesive. Try using a "hot air gun", these are available at the apron stores and affordable. I use one to heat the adhesive and it will get a bit soft, but not so soft it will pull apart. As stated, use a stiff scraper, sharpened at that, and hammer it into the glue. Do not use a flexible putty knife. After removal, clean up the vanity frame and a good idea not to use construction adhesive again, silicone caulk if fine.
Old 03-04-2011, 05:56 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can also realize great success using a garrote or ligature made from fishing line or guitar or piano wire string.
A guitar string has worked for me and you can generally find a place to thread it through an existing gap for a starting point.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
mem (03-05-2011)
Tags
bathroom , countertop , vanity
I need to know how to remove the front of a cultured marble tub hall.jacob Plumbing 8 09-12-2010 10:23 PM
Replacing bathroom vanity light bar AnnieO Electrical 2 07-28-2010 09:52 PM
Bathroom vanity rough in diyer4162 Carpentry 13 11-09-2007 06:36 PM
Sanding Cultured Marble Countertop? a2116 Remodeling 2 05-31-2007 05:39 AM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 10:10 PM
