| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Choosing a Replacement Thermostat
by Expert Village
Today we are replacing a bad thermostat. Now once you have it removed from the wall, you’ll have to scrape this and repaint it, I’m sure. But you want to make sure to get the right thermostat because you can cause some damage to your A/C or... Read More »
Removing a Broken Thermostat
by Expert Village
Today we’re replacing a thermostat will not cut off, it just continuously runs. Inside the A/C closet, which is right around the corner, there’s a light switch kind of like this one without a plate on it and you’re going to turn that... Read More » Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
Taping Glass for Shadow Box Frame
by Expert Village
Hi, this is Jon on behalf of Expert Village. In this video clip I will be talking about taping off the glass. Now that we have completed our final sanding we need to prepare our work piece to be able to stain it. What we're going to have to do is tape... Read More »
How to Clean a Rusty Razor Blade
by eHow.com
Sometimes you wind up with a rusty razor blade. Cleaning the razor blade can give it a new life and get rid of the rust and other issues. However, you'll want to use care in cleaning the blade so that you don't injure yourself or the razor blade itself. Read More »
