How To Reinforce Bouncy Floors? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-02-2010, 11:32 AM   #1
Rewards Points: 111
How to reinforce bouncy floors?
2x8 joists, 16 OC. Should I put 2x8 blocks between each joist in a staggered pattern? Right now there is 1x4 criss crossed, but that isn't helping much with deflection.
Any help is greatly appreciated.
luvdairish is offline   Reply With Quote
Old 11-02-2010, 12:02 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 506
I ran a drop girder under my floor and it is stable enough for tile, no bounce at all.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 11-02-2010, 04:30 PM   #3
Civil Engineer
Rewards Points: 4,854
Cross bracing is designed to reduce lateral deflection. It does not reduce vertical deflection (the bouncy part of your floor). In order to reduce vertical deflection, you need to do one or more of the following:
1. Reduce the span of the joist by installing an intermediate support beam.
2. Increase the moment of inertia of the joist by sistering another joist (doubles the MI), replacing the joist with a deeper element (replace 2x8 with a 2x10 for example), or bolting a plate on the bottom or the sides (increases the moment of inertia).
3. Replace the joist with a structural element with a greater modulus of elasticity (replace a wooden beam with a steel beam).
4. Reduce the load on the joist (difficult to do in residential construction).
In residential construction, by far the most common is sistering each joist. Blocking helps a little, because you distribute load across multiple joists, but the transfer is not very efficient, so the reduction in deflection is usually small.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
Old 11-02-2010, 07:18 PM   #4
Rewards Points: 5,336
Is this the same situation you said was 24" on center you were tiling on?
Ron
Old 11-03-2010, 04:01 PM   #5
Registered User
Rewards Points: 526
http://books.google.com/books?id=1uY...lywood&f=false
http://www.finehomebuilding.com/PDF/Free/021184090.pdf
Gary
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 08:50 AM
Refinshing floors before painting walls? ponchoman1 Flooring 6 03-14-2009 04:21 PM
Want to try to refinish hardwood floors and parquet floors proofer Flooring 11 04-20-2008 05:59 PM
Buckling of Laminate floors branjack Flooring 13 12-26-2007 12:38 PM
Washing my wood floors J187 Flooring 1 11-14-2006 10:13 PM
