How To Reinforce Beam And Remove Telepost - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-12-2009, 12:40 PM   #1
how to reinforce beam and remove telepost
heard i could atach steel plates to both sides.span is 17ft.if so what thick ness ,bolt type,spacing,pattern to use.all advice welcome.thanks
sperley is offline   Reply With Quote
Old 03-12-2009, 12:46 PM   #2
Rewards Points: 5,336
You need to call in a structural engineer for this. It can't be done over the internet.
Ron
Old 03-13-2009, 01:43 AM   #3
Registered User
Termite's Avatar
Your question definitely is too general for anyone here to be of any assistance. Kind of like asking "how long is a rope".
As Ron accurately stated, you absolutely must hire a structural engineer to design a way to retrofit the beam with more material. Welds must also be inspected to the engineer's satisfaction.
There are dozens of variables in play here...All of which must be part of the calculation.
Old 03-14-2009, 09:46 AM   #4
sperley
thanks,i dont want to do this but my husband does because his friend did.everything points to no for me.please send strong reasons why not,so he can read them.he already ordered steel.yikes
Old 03-14-2009, 12:44 PM   #5
Because your husband(probably) doesn't have the qualifications to figure this out. I'm not saying he's stupid, but that would be the case if he removed the post.
The replacement structure would depend on the loads involved over this area. I have 2, 10" steel "I" beams, 6' apart in my basement and still have steel columns every 8 '.
Hopefully you have a ranch so when it collapses, body recovery won't take too long.
Ron
Old 03-15-2009, 01:22 AM   #6
Registered User
Termite's Avatar
Oh good lord. Cancel or postpone the steel order.
Just because it is steel and the rest of the house is wood does not mean that the steel that he "specified" is plenty strong to do what he proposes. Furthermore, removal of the center post(s) adds considerable load to the outer bearing points, and they may not have the footings for it.
I've been in dozens of homes where people have tried major structural modifications on a DIY/wing-it basis and failed miserably...Either during the project or in the following months.
All I can tell you is that you can do this as a DIY job, sure you can. You just need some professional guidance from an engineer to calc the loads.
I sure hope he's pulling a permit.
Old 03-15-2009, 09:53 AM   #7
thanks
we will call in a structural engineer.thanks for the backup
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Question about steel I BEAM in basement djohns10 Building & Construction 7 06-23-2012 04:55 PM
LVL Beam / Load beam? tarr618 Building & Construction 29 02-01-2009 11:18 PM
Q:Temp support to replace beam and posts on deck dougq Building & Construction 10 09-02-2008 05:24 PM
