How To Reduce Mositure Issue On Basement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-28-2011, 12:44 PM   #1
Rewards Points: 87
how to reduce mositure issue on basement?
I think my 1950's poured concrete basement has big moisture issue due to the poor concrete. But fortunately we don't have water issue and above grade French drain has protected the house from surface water’s attack.
I have put two coats of Thoroseal Waterproof two years ago. Now efflorescence comes back and it is really bad (see the attachement or the link): http://www.flickr.com/photos/bostonjames1980.
I have contacted with Thoroseal and Quikrete to ask appropriate product for my case. Thoroseal recommends Thoroseal Plaster Mix and Quikrete recommends Quikwall Surface Bonding Cement
http://www.caribbean.basf-cc.com/en/products/Waterproofing/Cementitious_Waterproofing/Thoroseal_Plaster_Mix/Pages/default.aspx
http://www.quikrete.com/PDFs/SPEC_DATA-QUIKWALL.pdf
I am thinking finish the basement this winter. What should I do to deal the moisture issue with the concrete walls?
how to reduce mositure issue on basement?-img_3629.jpg   how to reduce mositure issue on basement?-img_3672.jpg
diy001 is offline   Reply With Quote
Wet basement - don't know where to start konradsa Building & Construction 17 09-20-2011 10:08 AM
what's the consequences of a well insulated basement diy001 Building & Construction 1 06-12-2011 01:13 AM
Over insulate basement? braverichard Building & Construction 26 06-22-2010 08:26 PM
Thoughts and ideas basement finishing and HVAC creamaster HVAC 1 03-10-2010 07:46 PM
Basement Floor issue with paint mjarema414 Painting 11 07-27-2009 10:01 PM
