How To Raise A Ceiling At An Angle - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 12:11 PM   #1
How to raise a ceiling at an angle
Hi,
So, I have been doing a lot of searches, and have come up empty handed. What I want to do is raise the ceiling in my bedroom at an angle to that one side is 9' and the other is about 13-14'. See below:
from the side
from the top
I don't know how the attic entrance would work when the ceiling it lift. Also, I have no idea what the rafters look like, but I believe they can be cut into are shifted to balance differently. I want the ceiling to be at an angle to that I can add a mini second level to my bedroom. The room to the back of the wall at the top/front is another bedroom/closet, and to the right is a hallway and left is the outside. I live in an HOA, so I can't expand, but I can go up! "but it can't affect the outside of the dwelling" haha!
Also, how much do you think this may cost. I don't exactly need dry wall from Africa, if you know what I mean....
Thanks!
EDIT:
I have trusses, and I do know they can be cut and balanced with steel beams, I was reading this in attic refinishing. Also, going off of another poster, I meant I don't want to spend the MOST expensive materials on the market. Thnx again!
Chesnut9 is offline   Reply With Quote
Old 11-21-2010, 12:26 PM   #2
Rewards Points: 1,010
No, I have no idea what you mean.
I'm sure it is merely innocuous and rather stupid, but one could infer a degree of cryptic racism in it also.
So do explain, please
Anti-wingnut is offline   Reply With Quote
Old 11-21-2010, 12:33 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
If you have no idea what the rafters, or trusses possibly, there is no way anybody can suggest anything. If you have trusses, it just isn't going to happen, period. If you have rafters, you are going to need an engineer to review what you have and give you legitimate options. There is no way to determine the structural design of your house without a full review of the structure.
Old 11-21-2010, 12:34 PM   #4
Sorry you didn't understand, I meant that I don't need the most expensive drywall, bolts... on the market. Sorry you got offended.
Old 11-21-2010, 12:37 PM   #5
Originally Posted by nap View Post
IIf you have trusses, it just isn't going to happen, period.
I do have trusses, just checked. Not very familiar with houses but the roof is at an angle, and it is built with the triangles.... trusses. I was reading in a few articles that if there are trusses in attics that want to be refinished, they can be cut and steel beams can be put in to balance them out. So it CAN be done!
Old 11-21-2010, 01:12 PM   #6
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,... You need an Architect/ Engineer,...
Not an internet forum for structual things like this...
Especially when you state you don't know Anything about it...
My guess is,... You'll be spending Tens of Thousands for the complete job,...
If it's even possible....
Bondo is online now   Reply With Quote
Old 11-21-2010, 01:15 PM   #7
nap
You talking to me?
nap's Avatar
Sure, whatever. You have no understanding what you are considering. Have at it. Just don't complain when the roof falls in.
Old 11-21-2010, 01:33 PM   #8
Ok! great thnx! I found another way to add more space to my room. and btw, mr lama. get real! yep! ur rite i have no idea about stuff like this. i am a dermatologist not a architect! thnx to everyone for helping!
Old 11-21-2010, 01:36 PM   #9
You went to college for, like ten years?
Old 11-21-2010, 01:42 PM   #10
Haha, yep.... but it is worth it.... I like to see people change dramatically after seeing me... I like change so that's why I was going to uplift my office i my house.
Old 11-21-2010, 01:44 PM   #11
Did you take spelling and grammar at any point?
Old 11-21-2010, 01:45 PM   #12
Hahaha! yeah in hs, but i don't rly need it now...
Old 11-21-2010, 01:54 PM   #13
Well, given that you are a specialized and highly trained MD, you should be able to recognize that your project should be possible, but that you need the professional abilities of a engineer and/or an architect, as well as a contractor.
Sawn lumber or TJI rafters are much easier to modify than trusses. the attachment of said assembly to the wall at a higher point may increase hinge points and load path. These are all subjects which anonymous strangers on a web site will be unable to diagnose.
You wouldn't want us to operate on our own moles from just paragraphs from the web, would you?
Old 11-21-2010, 02:11 PM   #14
Yeah, I know that it is possible, just I wanted to know how much construction would be needed and the price tag. Ok, I would bring it up with my contractor. I am about to post another thread on another idea I came up with. Seems it bit more pliable. Thnx again!
Old 11-21-2010, 02:21 PM   #15
here is my new thread with another space idea:
Cutting into wall to create a 24" tall by 15' wide crawlspace.
How to raise a seven foot ceiling to the standard eight foot ceiling Juan W Building & Construction 5 11-06-2010 04:22 PM
peeled ceiling paint off, how to fix? philosophical Painting 3 10-19-2010 04:28 PM
False ceiling... Why? jpelzer Building & Construction 3 06-03-2009 08:01 AM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 04:18 PM
ceiling fan support triplnikl Carpentry 5 03-06-2009 03:47 PM
