How To Prevent Mold In Knee Wall Cabinet Dressers - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-13-2010, 06:22 PM   #1
How to prevent mold in knee wall cabinet dressers
I have a 1950 cape that has built in knee wall dressers in each room. The cabinets are made of plywood which are poplar wood and the joints are very tight. The cabinets behind the knee wall are wrapped with 1/4 inch foil insulation to keep the cold air out. Both ends of the house behinds the knee walls are also 8x8 louver vents so there is adequate airflow behind the knee wall. The problem I just found was mold growing on the inside of the cabinets, mostly on the bottom. I assume because the wood was cold and the air from the room was warm, moisture was created which created the mold.
I need to know how to correct this problem. I have used a variety of chemicals to clean the mold but need to know how to correct the problem. I heard one option was to seal the inside of the cabinets with polyurethane. Any suggestions?
cxcarl is offline   Reply With Quote
Old 03-13-2010, 07:01 PM   #2
Rewards Points: 5,336
You need to provide a thermal buffer between the interior and exterior. If you can get behind the wall and vapor barrier it and insulate it, do it. If not, do it from the interior.
Ron
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
attic insulation / knee wall oscarMadison Building & Construction 2 01-19-2010 08:37 PM
Built-in cabinets/shelves in bonus-room knee wall flamtap Remodeling 2 10-26-2009 09:14 AM
Knee Wall Insulation nebaggie Building & Construction 2 09-30-2009 09:51 PM
Knee wall acess door Dan N Building & Construction 3 01-12-2007 09:13 AM
