-   -   How to place a floor drain in new concrete pour? (http://www.diychatroom.com/f19/how-place-floor-drain-new-concrete-pour-54871/)
walkman 10-10-2009 08:11 PM
I'm converting a portion of my crawlspace to a utility room. I want to install a floor drain for HVAC and WH.
How do I position the floor drain for the concrete slab pour? Does it have to be perfectly placed including height and secured with rebar driven into the ground or something like that? And then capped somehow so concrete doesn't get into the pipe?
Willie T 10-10-2009 08:32 PM
Pretty much.................. "Yes".... although threaded couplings give you some play.
joasis 10-11-2009 07:45 AM
1/4 inch per foot of slop minimum. If the room is say, 6 feet square, 3 feet would be the center, and 3/4 of an inch would be the slope. The drain/trap fixture would be pinned underside with rebar to hold it at height, and covered with ductape, making sure it covers the top only. If you do this yourself, mix the concrete at a stiff slump, and then you can use a 2-1/2 foot long piece of 2x4 to screed it out with.
Aggie67 10-11-2009 08:18 AM
When we install floor drains and floor sinks, we spend the extra few bucks to get the height adapter kits. Then we can set the height to exactly where we want it to be. You can jury rig it, but it goes so much quicker with a kit.
