How To Pick Good Boards For Studs? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 09:05 AM   #1
Rewards Points: 640
how to pick good boards for studs?
Well I am sorting through a pile of 200 studs... most of them seem perfectly straight, with maybe a slight twist in them... some of them are obviously bowed out, which go onto my blocking pile to make blocking out of... but I've always had problems with telling what is the crown of the board, how in the world do you guys do this by sight? I can look down the board with one eye open and see no curve or see an optical illusion of a curve that is not there when I check it with a laser line from end to end..
I've resorted to using the laser line and lineing up both ends to it to see if it is straight or not, seems to work ok, but takes a while...
any tips that could help?
BlueBSH is offline   Reply With Quote
Old 08-10-2011, 09:35 AM   #2
AGWhitehouse's Avatar
If the "by eye" method really doesn't work for you, you can make a jig. Take two boards and nail them together to create an L. Make sure to use two boards that are truly straight. Then you can lay in the unknown studs into the L and you'll see right away if there is a bow...
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-10-2011, 10:10 AM   #3
Rewards Points: 640
yeah thats a good idea.
I know there are tollerances for twist and crowning, any idea of what is considered a good stud? I know perfectly true is a yes, but I'm sure they don't build with 100% straight wood, I know walls I pulled drywall off of had a good bit of wane in them and twist
Old 08-10-2011, 10:14 AM   #4
Not sure what the exact measurements need to be. Don't forget that the wood will move more as it continues to dry out.
Old 08-10-2011, 10:19 AM   #5
Rewards Points: 640
oh yeah, that's always fun with pressure treated wood, always shrinking and twisting...
Old 08-10-2011, 10:20 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
When you view a board to determine crown and twist always use your dominant eye. Switching (eyes) back and forth to compare perceptions is confusing.
When studs are being installed be sure all crowns are in the same direction with out fail.
XXX
Old 08-10-2011, 10:27 AM   #7
kwikfishron's Avatar
Rewards Points: 90
I think you‘re way over thinking this. Why are you worried a crown or the illusion of one the eye can’t see?
Sheetrock and other coverings will float over miner imperfections and you’ll never know they exist.
kwikfishron is offline   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
12penny (08-10-2011), Ron6519 (08-10-2011)
Old 08-10-2011, 10:29 AM   #8
Rewards Points: 640
that's what I've tried to do, always thought my right eye was dominate, at least can see better with it
I guess my problem has always been trying to see the crown sometimes I can pick up a slight curve, sometimes it seems larger of a curve...
Old 08-10-2011, 10:48 AM   #9
Not so new
12penny's Avatar
Rewards Points: 520
Try holding it farther from your eye. I do studs almost at arms length.
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
Willie T (08-11-2011)
Old 08-10-2011, 10:59 AM   #10
Rewards Points: 640
until you trim it and those imperfections stand out as gaps...
Old 08-10-2011, 11:00 AM   #11
Rewards Points: 640
ah maybe that is my problem, not enough distance
Old 08-10-2011, 12:11 PM   #12
I work almost exclusivly with metal studs in commercial work, they are all stright until stepped on and are not effected by the humidity changes, they won't burn, twist, rot are easier to work with once you get used to them and come in many lengths and can be ordered in almost any length. they can be recycled when the house or structure is torn down and are made from recycled metal. I think it is the way to go
woodmeistro is offline   Reply With Quote
Old 08-10-2011, 01:08 PM   #13
Just found that humorous considering your handle...
The Following User Says Thank You to AGWhitehouse For This Useful Post:
Old 08-10-2011, 01:08 PM   #14
Rewards Points: 640
even in a basement against a block wall?
I already have the wood in this project though
Old 08-10-2011, 05:17 PM   #15
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Especially with block walls. That is what metal "hat-channel" is good for. Use hat-channel instead of wood studs and your worries are over.
XXX
Are they good Shenandoah Cabinets good quality? robertmazzo Carpentry 76 05-14-2015 10:23 PM
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 05:49 PM
Where to find good Bifold hardware & doors? smoochas Carpentry 3 07-14-2010 07:28 AM
Replacing Roof Boards joedadog Roofing/Siding 12 05-14-2006 11:10 AM
