Old 02-15-2007, 03:19 PM   #1
How much weight will a 4x4 douglas fir post hold?
support before it fails?
harleysilo is offline   Reply With Quote
Old 02-18-2007, 08:10 PM   #2
Licensed Remodeling GC
kevjob's Avatar
what is it holding up?
kevjob is offline   Reply With Quote
Old 02-18-2007, 08:28 PM   #3
concretemasonry's Avatar
How high is the post?
concretemasonry is offline   Reply With Quote
Old 02-19-2007, 08:12 AM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Other information would be a factor:
How many more 4x4's are also supporting the load, Where it's placement is in relation to the other 4x4's , what is the base (foundation)construction, where is it to be located, how will it be attached, What will it be supporting, what are the dimensions of the area under the load, what are the dimensions of the area to be supported, etc...etc..?
There are alot of factors that would determine the actual structural properties of a 4x4 ....
- Build Well -
Old 02-19-2007, 11:37 AM   #5
Can you use a metal column if you have concerns about failure?
redline is offline   Reply With Quote
Old 02-19-2007, 12:41 PM   #6
Wood bares the toleration of roughly 625 pounds per square inch (PSI) of a compression load.
Concrete can bare 3,000 PSI of a compression load.
Steel can bare 30,000 PSI of a compression load.
Don't quote me on this, but: "I believe" a Heavy Duty rated concrete filled column is rated at around 14,000 pounds at it's full height....with a good 12" deep concrete footing under it and proper attachement plates top and bottom....
- Build Well -
wood fence post farrington135 Building & Construction 11 05-17-2011 03:32 PM
Post mounted electrical receptacle ¯¯NI¯l¯RO¯¯ Electrical 13 04-19-2010 03:20 PM
Can Shenandoah Cabinets from HD hold weight for book cases/home Office? Leibrook Carpentry 3 12-10-2006 06:26 AM
