How Much Weight Can Garage Ceiling Studs Hold? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-23-2013, 11:33 AM   #1
How much weight can garage ceiling studs hold?
I want to put a pull up bar in my garage. But looking at the ceiling studs, I'm not sure how much weight they can hold. Its not one piece of wood that goes all the way across. Its 2 pieces that look stapled together or something. Here are some pictures. Can this garage ceiling hold enough weight for me to install a pull up bar and safely do pull ups from it?
The second picture shows a zoom in view of the 2 pieces of wood stapled or something.
How much weight can garage ceiling studs hold?-img_6860.jpg   How much weight can garage ceiling studs hold?-img_6862.jpg
limitdiy is offline   Reply With Quote
Old 07-23-2013, 11:47 AM   #2
Rewards Points: 6,652
There are no studs in a ceiling. They are called joists.
The big question is, how much do you weigh.
The Following User Says Thank You to gregzoll For This Useful Post:
Gymschu (07-23-2013)
Old 07-23-2013, 02:49 PM   #3
Thanks. Sorry about the vocabulary. I am not too familiar with this type of stuff. I wish I would have taken shop class in high school. Better yet, I wish there were classes like shop for adults at community colleges. I weigh about 160. Is that normal to use 2 separate pieces of wood and joining them together with that little metal plate with staples?
Old 07-23-2013, 03:00 PM   #4
Rewards Points: 252
I'd take a 2x4 and lag bolt it perpendicular (crossways) it to 3 or 4 of your trusses. That way your weight is spread across a couple of them. Closer to the wall the better.
shazapple is offline   Reply With Quote
Old 07-23-2013, 05:47 PM   #5
Civil Engineer
Rewards Points: 4,770
Those look to be pretty minimal trusses. Your best bet is to install the bar close to the wall. The further towards the center of the trusses, the more bending moment you put on the truss, and the more likely it is to collapse. But only your truss manufacturer can tell for sure what kind of load they are rated for. Just as an aside, most truss manufacturers are going to tell you that their trusses are not rated for pullup bars, so you are kind of on your own. As I said, if you want to do it, install the bar close to the wall.
Old 07-23-2013, 05:48 PM   #6
Do an off the wall bar. Problem with engineered trusses, unless you know what te "Dead Weight" limit is, you could easily pull the plates away, if you do quick reps.
What is the span and height of the trusses from peak to bottom chord piece?
Create Garage Ceiling For Insulating traeki Building & Construction 4 10-01-2011 10:11 AM
Insulate basement garage ceiling under living area? beckydewit Building & Construction 10 11-14-2010 11:59 AM
garage ceiling mferguson0414 Carpentry 2 01-13-2009 10:24 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
