How Much Torque For Foundation Bolt - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 10:17 PM   #1
Rewards Points: 113
how much torque for foundation bolt
the bolts are like the L shape ones, standard home depot stuff, 5/8 diameter. how much torque should i tighten it to? any rule of thumb number? i don't think it's waxed. how can i tell anyway? thx
oldhouse49 is offline   Reply With Quote
Old 10-22-2011, 10:42 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,116
According to the building spec in my area....snug the nut...then turn about 3/4 more.
Old 10-23-2011, 12:06 AM   #3
Too Old
Be sure you check before an inspection, the wood will shrink and the bolt will loosen. Usually the bolt is tightened at P&L then you get a shear inspection a couple days later. Depending on your area when you call for an insulation or mechanical inspection before you drywall the bolts will be loose if you do not check them. It's an easy write up for the inspector.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
Old 10-23-2011, 01:07 AM   #4
Rewards Points: 1,092
ALWAYS let them sit a few days and re-tighten them, maybe 2 or 3 times, and double up on the washers (of whatever size the inspector says you need). I do not think it is silly to use a lock washer as well, esp if you have a lot of seismic activity. You can Google for torque tables, but I suspect that the proper torque for a 5/8" NC bolt is more than the wood can handle, unless you have stiff 3" diameter washers, etc.
The Following User Says Thank You to jklingel For This Useful Post:
jomama45 (10-23-2011)
Old 10-23-2011, 08:48 AM   #5
kwikfishron's Avatar
Rewards Points: 998
I’ve always tightened bolts into wood to the point where when washer starts sinking into the wood you stop.
I never remember the boss saying “go back and check the bolts you tightened last week”. Not to say that maybe you should.
kwikfishron is offline   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
loneframer (10-23-2011), woodworkbykirk (10-23-2011)
Old 10-23-2011, 09:08 AM   #6
Rewards Points: 113
so can I still redo it with a lock washer after I had already tightened it ?
Old 10-23-2011, 09:18 AM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,328
exactly i do the same thing, when im setting mud sills i use a impact driver and once the washer starts to indent the wood its good..
why slow down your project by two days so you can go back and tighten down the nuts... as soon as my sils are down i start setting corners with a laser level then string my dry line to stick frame the knee walls
woodworkbykirk is offline   Reply With Quote
Old 10-23-2011, 10:02 AM   #8
Framing Contractor
Tighten down until the washer starts bending, that's all you need to do. Start framing. If you want to go back when your done framing for peace of mind go for it. You really don't need too.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 10-23-2011, 11:51 AM   #9
Residential Designer
AndyGump's Avatar
Rewards Points: 688
Send a message via Skype™ to AndyGump
You are in California, I don't think lock washers are allowed at any time.
The washer needs to be a 3" x 3", slotted, steel washer about .299" thick min.
That is over a quarter inch thick. Just snug them up until the washer sinks into the wood (like Kwikfish said) just a bit.
Andy.
AndyGump is offline   Reply With Quote
Old 10-23-2011, 03:58 PM   #10
true, earthquake zone codes will come into play for california
Old 10-23-2011, 05:21 PM   #11
Rewards Points: 6,652
Doesn't really matter where they came from.
Toggle / anchor bolt question masada Drywall & Plaster 3 07-06-2011 12:39 PM
Torque Letter? bigmacfann Electrical 14 08-11-2010 10:40 AM
Need Hex Bolt for Older Velux Skylight xquercus Roofing/Siding 0 05-26-2010 01:19 PM
Torque on a receptacle screw? Ultrarunner2017 Electrical 13 03-09-2009 03:35 PM
Attach a bolt to drywall hdayanan Building & Construction 1 03-17-2006 07:01 AM
