How Much Top Soil To Fill In This Hole - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-26-2007, 10:14 AM   #1
Rewards Points: 398
How much top soil to fill in this hole
I have a round hole that is 8 feet in diameter and about a foot to foot and a half deep. I don't even know how they sell top soil, but I was wondering how much would be needed to fill in th is size hole.
Malcolm is offline   Reply With Quote
Old 07-26-2007, 10:50 AM   #2
Agent 000
SecretSquirrel's Avatar
You'll need about 2 1/2 to 3 yards depending on how close the depth is to 1.5'
3.1416 x 16 (pi r squared) = 50 sq ft surface area
50 x 1.5 deep = 75 cu ft.
75 / 27 (cu ft in a yard) = 2.7yards
SecretSquirrel is offline   Reply With Quote
Old 07-26-2007, 02:51 PM   #3
good old pi r squared. I hated math but it looks like someone was paying attention. You can buy top soil by the bag (expensive) or you can go to a nursery or mulching place and they sell it by the yard (need a truck). Most places have a backhoe so no need to shovel it into the truck. When you get home the shovel and wheelbarrow will be needed .
warnerww is offline   Reply With Quote
Old 07-26-2007, 03:15 PM   #4
Rewards Points: 398
I was told a yard weighs a little over a ton. I have a truck but it can't handle that payload. That would be a lot of bags of top soil.
Old 07-26-2007, 03:20 PM   #5
Agent 000
Malcolm, I was thinking... instead of paying a premium for topsoil why don't you get some regular fill dirt to fill in most of the hole, then cover with about 4" of topsoil. Having premium grade dirt buried down that low doesn't really accomplish a whole lot unless you have some very unique needs.
Unless you live in the sticks the mulch/dirt outfit should be able to deliver it right to you... and if you're lucky, back right up to the hole and dump it in.
Old 07-26-2007, 03:40 PM   #6
concretemasonry's Avatar
Rewards Points: 2,578
Your topsoil will compact down severely with time and moisture. The yard you buy will end being less than a yard in a month or so.
Use common fill and cover with the good stuff.
concretemasonry is offline   Reply With Quote
Old 07-26-2007, 03:50 PM   #7
Ok I do live in the sticks I have to go 90 miles to get top soil. I am not sure what it weighs I put 2 yards in my 3/4 ton truck. It does not like it but it is a truck and 90 miles is a long way to go. It is a good point though that you do not need to fill the entire hole with top soil.
Old 07-26-2007, 04:12 PM   #8
Rewards Points: 768
You can get a lot more than 1 yard for a ton. I just got river rock dumped (10 ton).
Every company that I talked to said that 100 sq ft. is approx. 1 ton of rock. So I would figure that 10 sq. yds. would be closer to a ton. Unless it is really packed.
cibula11 is offline   Reply With Quote
Old 07-27-2007, 07:29 AM   #9
Agent 000
I've gone to the Hertz construction rental before and used one of those Bri-Mar dump trailers to haul some wash stone... they can handle several tons. You just gotta be careful not to exceed your hitch rating.
Tool to deepen deadbolt hole? darsunt Carpentry 5 07-18-2007 11:45 PM
Question regarding soil makeup (will my soil amendment idea work?) joeyboy Landscaping & Lawn Care 5 06-30-2007 11:24 PM
How to seal an AC hole? kypper HVAC 11 05-07-2007 07:53 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
Sink hole under garage slab. diggitydog Building & Construction 3 08-31-2006 01:49 PM
