-   -   How much top soil to fill in this hole (http://www.diychatroom.com/f19/how-much-top-soil-fill-hole-10176/)
Malcolm 07-26-2007 10:14 AM
I have a round hole that is 8 feet in diameter and about a foot to foot and a half deep. I don't even know how they sell top soil, but I was wondering how much would be needed to fill in th is size hole.
SecretSquirrel 07-26-2007 10:50 AM
You'll need about 2 1/2 to 3 yards depending on how close the depth is to 1.5'
3.1416 x 16 (pi r squared) = 50 sq ft surface area
50 x 1.5 deep = 75 cu ft.
75 / 27 (cu ft in a yard) = 2.7yards
warnerww 07-26-2007 02:51 PM
good old pi r squared. I hated math but it looks like someone was paying attention. You can buy top soil by the bag (expensive) or you can go to a nursery or mulching place and they sell it by the yard (need a truck). Most places have a backhoe so no need to shovel it into the truck. When you get home the shovel and wheelbarrow will be needed:furious: .
Malcolm 07-26-2007 03:15 PM
I was told a yard weighs a little over a ton. I have a truck but it can't handle that payload. That would be a lot of bags of top soil.
SecretSquirrel 07-26-2007 03:20 PM
Malcolm, I was thinking... instead of paying a premium for topsoil why don't you get some regular fill dirt to fill in most of the hole, then cover with about 4" of topsoil. Having premium grade dirt buried down that low doesn't really accomplish a whole lot unless you have some very unique needs.
Unless you live in the sticks the mulch/dirt outfit should be able to deliver it right to you... and if you're lucky, back right up to the hole and dump it in.
concretemasonry 07-26-2007 03:40 PM
Your topsoil will compact down severely with time and moisture. The yard you buy will end being less than a yard in a month or so.
Use common fill and cover with the good stuff.
warnerww 07-26-2007 03:50 PM
Ok I do live in the sticks I have to go 90 miles to get top soil. I am not sure what it weighs I put 2 yards in my 3/4 ton truck. It does not like it but it is a truck and 90 miles is a long way to go. It is a good point though that you do not need to fill the entire hole with top soil.
cibula11 07-26-2007 04:12 PM
You can get a lot more than 1 yard for a ton. I just got river rock dumped (10 ton).
Every company that I talked to said that 100 sq ft. is approx. 1 ton of rock. So I would figure that 10 sq. yds. would be closer to a ton. Unless it is really packed.
SecretSquirrel 07-27-2007 07:29 AM
I've gone to the Hertz construction rental before and used one of those Bri-Mar dump trailers to haul some wash stone... they can handle several tons. You just gotta be careful not to exceed your hitch rating.
