How Much Stone - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-08-2009, 07:34 AM   #1
Rewards Points: 150
how much stone
I need to fill a area with crushed stone, it is 20'x30'x 4" how many yards of stone do I need?
econdave is offline   Reply With Quote
Old 04-08-2009, 07:54 AM   #2
joed's Avatar
Rewards Points: 12,862
By my calcs you need 7.4 yards. I believe it is about 1 ton per yard.
Old 04-08-2009, 07:58 AM   #3
Concrete & Masonry
Rewards Points: 568
Correct, about 8 yards, but depending on the stone, I would figure about 2500#'s per yard.
jomama45 is offline   Reply With Quote
Old 04-08-2009, 01:38 PM   #4
Rewards Points: 150
what is the formula for calculating that?? thanks for the response
Old 04-08-2009, 05:20 PM   #5
Concrete & Masonry
Rewards Points: 568
3' x 3' x 3' = 27 cubic ft., or 1 yard. If your putting the stone in at 4" thick (1/3 of 1 foot), multiply 27 X 3 = 81. Thus, 81 sq. feet covered per yard at 4".
A few more :
5" = 65
6" = 54
7" = 47
8" = 40
Old 04-08-2009, 06:23 PM   #6
joed's Avatar
The formula it length x width x thickness. If they are all in feet the the result is cubic feet . 27 cubic feet in the yard so it works like this.
20 x 30 x 4/12= 200 (4/12 to convert to feet)
now divide by 27 to get yards
200/27 = 7.4
Or you could do it all in one
20/3 x 30/3 x 4/36 = 7.4 (36 inches in yard, 3 feet in yard)
Old 04-08-2009, 06:50 PM   #7
Rewards Points: 150
o.k so how many tons and how do you do that?
Old 04-08-2009, 09:40 PM   #8
Concrete & Masonry
Rewards Points: 568
Tons per yard are far more specialized, depends on material, region, moisture content, etc. Call a local gravel pit for that info.
Insulating house with stone walls mlupa Building & Construction 3 11-26-2008 09:19 PM
Masonry Stone Archway jp33 Remodeling 8 01-31-2008 06:23 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
