How Much Space To Leave Around Windows? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2014, 03:41 PM   #1
How much space to leave around windows?
How much space do I leave between all the sides of a window? If I'm doing new framing, and I already know/have the windows I'm using, is it recommended that one still leave space and then shim and caulk, or can one just frame to the windows for a tight, exact fit?
MarcM is offline   Reply With Quote
Old 09-23-2014, 03:55 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Shim it, 3/8" to 1/2" seems to be the standard on the sides.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 09-23-2014, 03:57 PM   #3
Wait? Are you saying 3/8" to 1/2" is what I should leave around the sides? I thought at most, it would be like 1/8" of space all the way around.
Old 09-23-2014, 04:00 PM   #4
AndyGump's Avatar
Rewards Points: 684
I don't know what you should do, all I am saying is that 3/8" - 1/2" on the sides in pretty much the norm.
Do what you want to.
Andy.
Old 09-23-2014, 04:08 PM   #5
Rewards Points: 144
I make my rough openings 1/2" wider and 1/2" higher then the window.Most go 1" X1" leaving 1/2" all around.I go half that because I know my framing is square and it takes less to shim.This is on new construction.If you are reframing an old structure your better to go with an inch each way.
You don't shim and caulk the opening.You shim and insulate.
mako1 is offline   Reply With Quote
Old 09-23-2014, 05:06 PM   #6
I always leave 1/8" for movement.
ron45 is offline   Reply With Quote
Old 09-23-2014, 07:04 PM   #7
Rewards Points: 480
1/8 is not enough. RO should be 1/2" taller and 3/4" wider than the window itself. For the absolute correct answer, look at the instructions on the window itself which will give you both the window size AND the RO size. The idea of the RO being decently bigger than the window itself is to allow you to get the window sitting level and square in the opening. If there is 1/8" all around, and you need to go up a quarter in the lower left corner, you can't
And sure, all of the professionals will say that their openings are dead on.....but studs warp and bow, walls get racked when they are raised, workers might not be as careful as the guy in charge, etc.
It is WAY easier to leave extra than to have to take the wrecking saw to the side or top of an opening to give you room to level up a window. Ron
ront02769 is offline   Reply With Quote
Old 09-23-2014, 07:12 PM   #8
Rewards Points: 13,968
Making it to small can make a simple 10min. install become an hour or more.
There would be no room to fit the nozzle on the spray foam to insulate.
Old 09-23-2014, 07:25 PM   #9
Rewards Points: 144
I have always found that 1/2 "on each side is more than suffiecient.If you need more than that you better check your previous work.
Old 09-23-2014, 08:25 PM   #10
Measuring the rough opening and subtracting a 1/4", this gives you 1/8" on each side. If you have just built the rough opening and need more then that you had better get a different tape, level, pecil, eye, etc..
Old 09-24-2014, 07:09 PM   #11
Rewards Points: 480
OR, you could be the guy that follows the manufacturers instructions for the R/O and has no worries. Ron
Old 09-24-2014, 10:00 PM   #12
Rewards Points: 469
35 years in construction and its always been 1/2 inch on both sides and 3/4 top, Shims are cheap, turning a easy job into a royal pain in the a$$ ain't worth making the RO smaller
Jnaas2 is offline   Reply With Quote
Old 09-25-2014, 09:18 AM   #13
30 years in the business.....
If you just get done framing a wall and you need a 1/2" on each side of your rough in.?
The OP states...
" If I'm doing new framing, and I already know/have the windows I'm using,"
Old 09-26-2014, 09:10 AM   #14
Rewards Points: 126
2-1/2" to about 4" around the window.
jack45870 is offline   Reply With Quote
Old 09-26-2014, 08:23 PM   #15
Rewards Points: 1,910
It's usually best for DIYers to use the RO specified by the window manufacturer.
Sealing off a Crawl Space arblargan Insulation 12 09-11-2014 10:41 AM
New windows and siding - my experience Marty1Mc Windows and Doors 0 08-05-2012 08:29 AM
Replace just two windows - dumb idea? ChrisJJ Windows and Doors 13 06-01-2012 10:31 AM
69 year young lady struggling with windows robaire Windows and Doors 6 01-18-2012 07:01 AM
Pella Windows - Serious Frost Issue snowman72 General DIY Discussions 22 07-08-2011 12:39 AM
