How Much Rebar And Mesh Is Needed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 01:07 PM   #1
Fire Fighter-
Klint's Avatar
How much Rebar and mesh is needed
My contractor ask me to go buy the re-bar and mesh from a local store. My slab is 60' x 20' and want the re-bar set on 18" centers how much mesh and re-bar should I buy?
re-bar (3/8") is 20' pieces ($3.15 ea)
Mesh is 8' x 20' ($34.00 ea)
Thanks,
Klint T.
Klint is offline   Reply With Quote
Old 09-27-2011, 01:19 PM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
do a google search for a rebar calculator. I imagine there would be a few of these available to figure it up quick and easily
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 09-27-2011, 01:23 PM   #3
Fire Fighter-
Klint's Avatar
You have to pay for all the ones I found.
Thanks,
Klint T.
Old 09-27-2011, 01:26 PM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
i just saw this one, looks like it's free ( hit START THE CALCULATOR at top or bottom of the page) . You need to be smarter than me to understand it, but that shouldnt be too hard
http://www.pjsrebar.com/index.php?op...id=69&Itemid=0
Old 09-27-2011, 01:30 PM   #5
Fire Fighter-
Klint's Avatar
That is to calculate how much weight the re-bar can hold I need how many pieces.
Thanks,
Klint T.
Old 09-27-2011, 02:16 PM   #6
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
See, i told you i wasn't that smart.
take a look at this http://www.meet-mr-concrete.com/conc...culations.html maybe that will help more
Old 09-27-2011, 02:29 PM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why do you need rebar AND mesh?
Seems like an awful lot of steel for no good reason.
Quickly I get: 118 sticks 3/8
8 rolls mesh
$637.40
Old 09-27-2011, 02:50 PM   #8
Rewards Points: 4,640
its more distressing a grown man can't solve this arithmetic problem,,, if would be different IF the question were how much is the required overlap so the bar can be wired OR mesh overlap
bar o'lap - diam of bar X 10 - mesh o'lap - 4" HOWEVER no mesh in the joint(s) OR 5" on either side of it
stadry is online now   Reply With Quote
The Following User Says Thank You to stadry For This Useful Post:
concretemasonry (09-27-2011)
Old 09-29-2011, 03:24 PM   #9
concrete contractor
You need about 2000ft of rebar (100 20ft bars). The bars running the 60ft length should overlap at least 18" where the ends meet. You DON'T need wiremesh. Good luck.
johnnyconcrete is offline   Reply With Quote
Old 09-29-2011, 08:17 PM   #10
Concrete & Masonry
Rewards Points: 568
My quick math (rounding up) comes to about 85 rods & 9 sheets of mesh. I,too, wouldn't use all of that steel in the slab, unless you plan on some heavy vehicle traffic.
BTW, are you sure the sheets aren't actually 8' x 15'????
jomama45 is offline   Reply With Quote
Old 09-30-2011, 12:33 AM   #11
Rewards Points: 1,092
itsreally: is #3, 18" OC skookum enough? I'd be inclined to shorten that to 12" w/ 3#, or 16" w/ #4 on a 60' slab. Is that overkill? thanks. j
Concrete Patio, Rebar or wire mesh? frankenswat Building & Construction 8 10-11-2010 08:09 AM
Wire mesh or Rebar and their requirements vk77usa Off Topic 4 05-18-2010 12:54 PM
Rebar for Monolithic Slabs portert0224 Building & Construction 1 07-03-2008 11:37 PM
Rebar Placement in a 3x3 concrete pad. Top, bottom or middle? Deck Building & Construction 32 05-11-2008 08:44 AM
radiant vapor barrier bjherron Flooring 18 08-06-2007 06:15 AM
