How Much Load Can This Support? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-28-2010, 11:47 AM   #16
Located in Long Island. I dont know snow load. Looks to be 16" spacing
g60vwr is offline   Reply With Quote
Old 04-28-2010, 12:10 PM   #17
You need to verify distances...can't really estimate
Distance between roof rafters 16", 24"
Distance between 2x4's - 16" , 24" ?
Span of the 2x4's to inside edge of wall stud
2x6 rafters 16" OC are the min rafter required depending upon distance between rafters & exact span
The 2x4's do not meet code for a ceiling joist or to hold any weight
The 1x2 is holding the 2x4 up, placing more weight on the roof structure
Adding weight to the 2x4's adds the weight to the roof
With min sizing on the roof rafters & living in a snow area a snow storm could cause the whole roof to collapse with that added weight across the 2x4's
That is the concern & why everyone is saying this is not built to hold any weight
Exact measurements & spans are needed
But basically this was never built to hold weight
Old 04-28-2010, 12:26 PM   #18
thats understandable. im sure it was all previously built by homeowners not prefessional builders.
Ill get you guys measurements, as I really dont know anything about this, I was told that they used to store lots of things up there (there is even a pull down staircase) but i know that doesnt make it right
Old 04-28-2010, 03:03 PM   #19
I wouldn't add any load to that without reinforcement.
How is the truss going to support the load?
Houston_Bldr is offline   Reply With Quote
moving a support wall 6 ft over.? help jstamps Building & Construction 1 04-20-2010 06:48 AM
Help 30 amp Load center for my HID lights and miscellaneous Mont@n@ Electrical 9 03-06-2010 12:49 PM
extra support of the load bearing wall redcloud Building & Construction 11 06-22-2009 05:35 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
How much load can a 20' long 2x8 support? GrdLock Building & Construction 9 06-29-2007 12:15 PM
