Old 06-28-2007, 08:24 AM   #1
How much load can a 20' long 2x8 support?
We're converting our garage into an apartment. It has 5 20' long 2x8 beams going across the ceiling. We are making the ceiling have visible beams, with the sheetrock above them. On each beam, we nailed a series of 2x8 boards onto the sides of them to make the beams look thicker.
My wife is concerned that nailing those other beams up to the beams already there would make them too heavy, and that we need to put posts up in the middle of the room to support them. I don't feel these posts are necessary, and the fuill length 2x8's already there can easily support the added weight of the 2x8's we nailed onto the sides of them.
Basically I'd just like to find out exactly how much weight a 20' 2x8 board can support?
GrdLock is offline   Reply With Quote
Old 06-28-2007, 01:23 PM   #2
google span calculators to give you a better idea.
2x8 are not used for floor systems
You will probably need a beam running perpendicular to the 20' 2x8 somewhere in the middle to seperate the span to 2 10' spans to be able to use the space above.
a 20' 2x8 will not carry very much load at all.
cibula11 is offline   Reply With Quote
Old 06-28-2007, 01:40 PM   #3
common sense tells me to listen to the wife. It's easier to put in the beams now than to listen to "I told you so's" down the road.
What have I done is offline   Reply With Quote
Old 06-28-2007, 01:44 PM   #4
But when you do it..you have to come up with a reason other than the reason she gave. Otherwise she will have been right.
Man Law!!!
send_it_all is offline   Reply With Quote
Old 06-28-2007, 01:52 PM   #5
There won't be anything on the 2x8's except sheetrock. There isn't gonna be a floor above it, that's just the ceiling. We're not building an apartment ontop of the garage, we're just replacing the garage with the apartment.
Old 06-28-2007, 02:49 PM   #6
2x8 spaced 24" o.c. can span 14 ft. 8 inches.
spaced 16" o.c. they span a max of 16 ft. 10 in.
Do you know what your ceiling joists are spaced?
Old 06-28-2007, 04:21 PM   #7
Electrical Contractor
How are you going to attach the sheetrock between the spans would be my only concern with your scenario.
terrynistler is offline   Reply With Quote
Old 06-29-2007, 08:06 AM   #8
There's a picture of the ceiling so far.
Old 06-29-2007, 10:24 AM   #9
Add a closet or something if you don't want the hassle of a bunch of posts breaking up the room. Just make sure that each stud used in the closet become load bearing and supports the ceiling joists. It looks like you have a couple of posts supporting part of the ceiling. Are these just temporary. You could always keep them and then dress them up after you finish. Get some stone or just drywall them. It might look nice.
Since nothing will be put upstairs you should be okay. What size of sheetrock are you using? Since it rests on top of the joists, you could use 3/8" which weighs 20 lbs less then a 1/2" sheet.
Old 06-29-2007, 12:15 PM   #10
We're gonna put a thin laminent sheet all around the beams to encase them to look like one big beam, and stain it. As for the sheetrock, ya, it's 1/2"... I dunno why we didn't think about getting a thinner sheet for the ceiling, but oh well, too late now.
We've got a wall under one of the beams, but there's still two others that remain unsupported.
More On This Topic
On behalf of expert village, my name is Gregg Tauriello. I'm from suite 16 studio. I'm here to talk to you about soundproofing your recording studio. On this building I have T-111 siding on the outside, which is a standard cardboard siding that you will... Read More »
If moving walls is in your plan, there are several things to consider. You want to consider what is in the wall. Is there electric in the wall? Is there plumbing in the wall? Where is it? Where can you move it? Can you take it out? What would be the... Read More »
Hi, I'm Bob Street with Houdini Home Repair on behalf of Expert Village. In this clip, we will carry the beam up the ladder, clamp and shoot the nails. It's bad when your help don't show up, you've got to use a camera. Are you ready? How you feeling? You... Read More »
My name is Shannon Kniep on behalf of Expert Village, I'm going to show you how to cut a piece of sheetrock. We got the measurements up on our ceiling which is what we need in order to know the size of the piece that's going to fit in there. And it is... Read More »
My name is Shannon Kniep, I am speaking on behalf of Expert Village. When you are cutting on the sheetrock you want to make absolutely certain that you cut in the middle of the joiced. Not the edge of either side but in the middle, so that the piece that... Read More »
Load Calculation ? RM575 HVAC 9 07-04-2007 01:37 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
moving another load bearing nailfun Carpentry 2 02-20-2007 09:10 AM
Beam Load Ron Building & Construction 5 09-17-2006 07:28 AM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 07:36 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
