How Much Joist Sitting On Sill Plate? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-04-2009, 11:48 AM   #1
How much Joist sitting on Sill plate?
Building an addition and it looks some of the 12 ft wide (16 foot long) joists have only 1 inch sitting on the Sill (or upstairs wall). There is a joist running perpendicular which appears the joists are nailed into. Is it ok with only 1 inch of a 16 foot span is sitting on the plate but nailed into another 6 foot x 12 inch high joist that is also sitting on the Sill plate.
Also, which is better for a 16 foot joist span, solid wood blocking between joists or cross bracing at center (8 feet)?
Thanks for any help.
scott j is offline   Reply With Quote
Old 05-04-2009, 03:43 PM   #2
Registered User
Rewards Points: 5,492
1-1/2" minimum per 2003 UBC, IRC. Hanger them for load deflection on joists that long.
Bridging-- page 749: http://books.google.com/books?id=DWs...um=4#PPA747,M1
Be safe, G
Old 05-06-2009, 04:11 PM   #3
2 inches
Been framing for 15 years, have heard 2" bearing is the standard since year one. 3 1/2 inch plate, rim takes up 1 1/2, leaves 2 for the joists. The span isn't relevant.
Hang those.
Or if the sill is on block or concrete and there is room, add more sill under the joists. (pressure treated).
VaViaCo is offline   Reply With Quote
Old 05-06-2009, 05:08 PM   #4
Registered User
As VaVia said, you should have 2" there, what happened?
In the UBC, '76, '83 and 2003, (ones I bought new), the minimum bearing on wood is 1-1/2", UBC 2320.8.2.
Be safe, G
Old 05-07-2009, 05:32 AM   #5
Rewards Points: 5,336
When I do additions, I use a 2x6" sill plate, so you would have 4" bearing on the plate.
Why would you use a 2x4 as a sill plate. It seems skimpy to me to have the house bearing down on 2" of wood.
Ron
Old 05-07-2009, 08:26 AM   #6
Registered User
Termite's Avatar
Bearing's been pretty well covered.
As for the question about bridging/blocking...
Cross-bridging or solid blocking at mid-span will work equally well. The nice thing with bridging is that you can still run plumbing and electrical through it.
Old 05-08-2009, 12:59 PM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
Ron
OP said it's a second floor joist. There are millions of homes with second floor joists bearing on 2" of top plate in the exterior walls. Sounds like some-one doubled the ring joist in a short area. That doesn't leave enough bearing. I'd use some joist hangers in that short span.
Old 05-08-2009, 08:07 PM   #8
I guess I should pay closer attention to the details.
Ron
Old 02-03-2010, 10:00 AM   #9
Hanger
Thanks all! City inspector said to just slide a hanger under it. Looks good.
Replacing Rotten Sill Plate Material Tester Carpentry 6 03-28-2011 08:08 PM
rotted sill plate, joist ends and stud bottoms oh my. slowjo Building & Construction 16 05-02-2009 09:43 PM
rotten sill plate replacement mrad777 Carpentry 3 10-28-2008 12:19 PM
Rotted sill plate replacement help handyd123 Building & Construction 2 08-25-2008 06:02 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
