How Much Gravel To Order? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-13-2008, 09:27 PM   #1
How much gravel to order?
I need 4" of compact gravel on a 4'x10' area.
So that basically has a volume of 0.5 cubic yards.
How much does gravel shift when compacted? Do I need to order twice that amount?
TIA!
grumpybear is offline   Reply With Quote
Old 06-13-2008, 10:28 PM   #2
Registered User
Termite's Avatar
Gravel won't compact much. Gravel is sold by the ton, but your supplier can get you close to half a yard. More gravel never hurts anyway!
Old 06-14-2008, 05:37 AM   #3
good rule of thumb's been 110# per sq yd @ 1" depth,,, figure out that part & divide by 2,000 = enough for the job,,, i come up w/.98 ton or a small pickup load.
IF gravel ' shifts ', either it wasn't compacted OR the sub-base is soft.
caution you're not crushed or killed by falling/creeping/sinking gravel,,, noticed there's a danger inherent in this work according to the forum gawds
yesitsconcrete is offline   Reply With Quote
concrete funnel for gravel? Moritz Building & Construction 5 04-13-2008 09:07 PM
leaking tar and gravel roof meleis Roofing/Siding 9 01-05-2008 10:27 PM
3/4" Gravel on Sloped Driveway not locking - help? WynsWrld98 Landscaping & Lawn Care 7 10-17-2007 11:02 AM
