How Much Excess Siding To Order? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-14-2010, 10:22 AM   #1
Rewards Points: 262
how much excess siding to order?
I measured out the house and garage, coming in at 1,730sf (yes, its a small house). I know you can't use every inch of every piece, is there a "rule of thumb" on how much extra to buy? I was thinking 20sq=2000sf=15% surplus. Too much? Too little? Thanks!
moneymgmt is offline   Reply With Quote
Old 05-14-2010, 11:47 AM   #2
Next Time...New Build
Rewards Points: 150
I would think that 20 sq would be plenty, if not a little overkill. You are going to have your cut outs from your windows/doors, etc. which could be used in other spots as well.
THere are always the inevitable miscuts of which you will have a little back up. Also, that will leave you with pieces to replace with in the future if needed.
You could always build a dog house and use it up there......
RickyBobby is offline   Reply With Quote
Old 05-14-2010, 06:13 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
if its not a special order id bring in 16 sq and pick up more as i needed it
Tom Struble is offline   Reply With Quote
Old 05-14-2010, 06:42 PM   #4
kwikfishron's Avatar
Rewards Points: 344
How did you come up with 1730sf. Did you measure straight wall footage or did you deduct for all your openings?
On a average home (17-23 windows) I measure total wall footage and don’t deduct for windows and doors other than garage doors and go with that. Of course if you have a “wall of glass” somewhere that changes things a bit.
The big thing is the “return policy” if its “special order no returns” then I always order a little short and when I get close to the end order the rest. In my area anyway I can get just about anything twice a week so this usually doesn’t slow me down.
If returns are no problem and the siding is something like Cedar or Redwood Lap I always get extra from the start because there will always be boards I just won’t use and will return.
kwikfishron is online now   Reply With Quote
Old 05-15-2010, 04:28 PM   #5
Depends what kind of siding you're using. Wood has less useable scrap than vinyl. I would generally go with 10% over unless there is a disproportionately high or low number of window/doors. Also add more if there are a lot of angle cuts following a roof line
mrgins is offline   Reply With Quote
siding, soffits, gutters - order? johnny331 Remodeling 1 06-15-2007 04:11 PM
Removing excess deck stain from vinyl siding sleepy23 Remodeling 7 05-16-2007 07:13 AM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 12:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 03:35 PM
