How Much Deck Pitch? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-30-2012, 07:44 AM   #1
How much deck pitch?
What is the general rule for the pitch of a deck so that water runs away from house?
MisterSteve is offline   Reply With Quote
Old 09-30-2012, 07:51 AM   #2
DIY staff
Rewards Points: 7,174
Wood deck?
Old 09-30-2012, 08:03 AM   #3
Rewards Points: 12,802
If it's just a pressure treated wooden deck and is built right there is no pitch needed.
Got any pictures or more info, sure would help so we do not have to guess.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
oh'mike (09-30-2012), woodworkbykirk (09-30-2012)
Old 09-30-2012, 09:49 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,... The few I've built, I built in 1/4" in 10' for pitch, runnin' the length of the boards, away from the building...
The Following User Says Thank You to Bondo For This Useful Post:
AtlanticWBConst. (09-30-2012)
Old 09-30-2012, 10:26 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
There is no specific code or regulation.
However, we have always set them at a pitch as Bondo stated above. It is not noticable to the human eye.
- Build Well -
Old 09-30-2012, 01:51 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
a regular deck doesnt need pitch. the water will run off betweeen the boards
if you using duradeck treat it as a flat roof. frame the deck level then create furring strips to create 1/8 " per foot slope or whatever duradeck recommonds
woodworkbykirk is offline   Reply With Quote
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
foundation walls to support a deck bubbler Building & Construction 1 04-12-2012 04:27 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
