How Much Concrete Mix? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-08-2009, 05:18 PM   #1
How much concrete mix?
I will belaying about 400 8*16 blocks. It will be hollow wall. How many bags of 80 lb mix do I need?
Thanks in advance for assistance
Ismail
ptcamaro is offline   Reply With Quote
Old 08-09-2009, 10:19 AM   #2
If you're talking about bags of mortar, where you add the sand and water, then you'll need 10-12 bags (each bag, mixed with 3 parts of sand, will do approx. 35-40 8x8x16 block). If you're buying the sand/mortar premixed, then you'll need 40-45 bags (each bag does 8-10 block).
Mthrboard is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Help!: 4" concrete over 2' dirt over 7/8 wood planking! agent99 Flooring 4 04-28-2009 09:21 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
Need to expand existing concrete pad for A/C unit miketegra Building & Construction 2 07-03-2005 11:27 PM
