How Much Cement To Use???? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-04-2009, 03:41 AM   #1
How much cement to use????
I am building a 24x32 shed/shop with a second floor and I am constructing it on 4x6 piers approximately 4-6 feet off the ground. I am planning on spacing them every 5 feet and doubled on the corners. Is this sufficient enough for the weight and how much concrete should I place for each pier? I was planning on using an 80lb bag for each, placing approx. 30lbs at bottom for a plate and then using the remainder(50lbs) to place around the pier. I am placing them approx. 2ft in the ground. PLEASE someone give me an opinion!!! Thank you for your time
MyFrogsPistol is offline   Reply With Quote
Old 06-04-2009, 04:23 AM   #2
This is question your engineer, code officials, and inspectors need to answer.
jerryh3 is offline   Reply With Quote
Old 06-04-2009, 05:57 AM   #3
Not enogh info, location, this is not a DIY project, unless you are a building contractor. You require engineering solutions to a major project, out of the realm of the average DIY.
Old 06-04-2009, 06:05 AM   #4
Old School
Willie T's Avatar
Although you will need to get a better handle on this, I can tell you now that you are going to be WAY short in your calculations.
The "average" pad (just the rectangular bottom part) is usually about 24" square, and about 12" thick.
EACH pad of the size I just mentioned will require either about 9 60# bags, or about 6 80# bags of concrete. That's for EACH one... not even counting the piers.
And, NO, I'm not kidding with these amounts.
Willie T
Old 06-04-2009, 06:27 AM   #5
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 826
It doesn't sound sufficient. I also don't see enough info. Building something like this the DIY way can be incredibly fun and rewarding, but a key first step is putting together a proper design. It sounds like you don't have building plans. You need something to guide you. For something like this, I'm sure there are plans available online that you could buy that would provide all the detail you need. Or hire someone to do the plans if you don't have the experience (my state lets you do your own plans). I also don't see how you'd get a building permit for a 2 story structure without a set of plans.
But to address your question on piers: an 80 lb bag of concrete will only be enough for a round footing 12 inches in diameter and 10 inches thick. Around here, that's not enough. Also, piers every 5 feet sounds like a really uneconomical way to build a shop type of building. But again, I don't have a lot of info to go on.
Things you need to consider for sizing the footings:
1. Frost line depth, that tells you how deep to go
2. Loads from the structure transmitted to each pier (you need to know all your loads, dead, live, wind, rain, snow, seismic, if any), to calculate the load on the soil
3. Bearing capacity of soil, to size the pier based on the load you calculated
That's my humble advice. Also post back with more info on the structure, and maybe we can help some more.
Aggie67 is offline   Reply With Quote
Tags
cement needed , help with foundation , how muchpiers/cement
installing Slate title to outdoor cement Matky Flooring 53 04-05-2010 07:08 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 04:24 PM
Rotten cement - skim coat or board? BradG Building & Construction 1 11-25-2007 02:25 PM
cement falling into basement from cement porch above. Betsy G Building & Construction 3 10-21-2007 12:53 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 01:07 PM
