How Much Blow In Insulation? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 09:23 PM   #1
How much blow in insulation?
My daughters room is hot in the summer and cold in the winter. Tonight I decided to go in the attic and measure how deep the blow in insulation is. And it was 8'' at the highest spot but mostly about 6.5'' everywhere else, including my daughters room. How deep should it be? By the way if it matters my house was built in 2007, and it is a two story.
JasonJr is offline   Reply With Quote
Old 11-06-2010, 12:23 AM   #2
Rewards Points: 1,092
It depends. What zone are you in? Therefor, what does your code call for? Codes are minimums, btw. What will be holding the insulation up? Sheetrock thickness and joist spacing is....??? If the structure is there to support it, and you are in a cold place, pretty much "as much as you can afford now, and put the rest in later" is my answer. If I recall correctly, blown in cellulose (not sure what you have) is about R3.5/inch. R35-60 is pretty typical in lids.
Old 11-06-2010, 12:45 AM   #3
jlhaslip's Avatar
Rewards Points: 354
14" is minimum (code) here where I live.
My ceiling has 16" in it.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
Fiberglass Insulation: How Do I Cover the Attic? chueh Building & Construction 3 11-08-2010 03:33 PM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
blow in insulation ( paper ) deck hand Green Home Improvement 4 01-10-2009 10:57 PM
Blow in insulation Iowabucks General DIY Discussions 1 10-09-2007 09:20 AM
