How To Mount - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-25-2010, 09:55 PM   #1
How to mount
Mounting a hosepipe mount to brick. Do i drill the bit in the mortar joint or into the brick. What type of screw, anchor, and bit to use? Thanks...
Swann294 is offline   Reply With Quote
Old 08-26-2010, 08:09 AM   #2
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
mortar joint is easiest, depending on the brick it might even be strongest!
are you talking about just a pipe strap or hose bibb? if so you can just use sheetmetal screws and plastic anchors. use stainless screws if it's on exterior. easy and straightforward
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Any tips for putting up a VESA mount or TV Mount sevenupcan Building & Construction 8 07-13-2009 06:37 AM
Plasma TV Mount problem - one of the 4 screws cannot hit a stud..... wasserkool Home Theater 4 01-05-2009 08:24 PM
TV mount on drywall/metal studs? drewnyc Home Theater 4 11-11-2008 03:28 PM
How can I mount this? callmedpit Home Theater 8 10-10-2008 11:29 AM
Bracket to Ceiling mount a Wall mount floodlight Ski Electrical 1 06-27-2008 11:18 AM
