How To Mitre Bullnose Corner Bead?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-27-2008, 08:54 AM   #1
Willing to learn
Question
How to mitre bullnose corner bead??
Hi
My house has all rounded corners and we are finishing basement - want to use the same bullnose corner bead.
How do you cope/mitre so that inside corners of the bead match up?? Ive used a lot of waste bead trying to figure this out.
I know that there are PRE MADE corners - but like crown I figured I can forgo the extra cost of the premade corners and figure it out.
If anyone knows how to do it - PLEASE HELP!
otherwise I'm driving back to the hardware to buy pre fab corners
Arbs
Arbs is offline   Reply With Quote
Old 01-27-2008, 09:19 AM   #2
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
If you are referring to Bullnose DRYWALL corner bead, just go and buy it. H.D. carries it. There are actually different radius sizes that you can get, at drywall supply places.
If that is what you want (drywall bullnose), then the option is to just purchase it.
- Build Well -
Old 01-27-2008, 11:19 AM   #3
You need to use the premade corners. Anything else would just seperate and crack.
jerryh3 is offline   Reply With Quote
Old 01-28-2008, 12:32 PM   #4
Rewards Points: 150
Arbs-
I posted the same question a while back, and I found no magic solution. Back to the premade corner store I went. I was actually trying to miter a bullnose edge around a window with a kerf. The only premade corners I found had a "3rd leg" that I just cut off so it fit into the kerf.
steve1234 is offline   Reply With Quote
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 07:38 AM
Drywall corner bead Question dk_99 Building & Construction 5 01-01-2008 03:25 PM
Repair damaged bullnose corner DRCollier Building & Construction 2 07-15-2007 09:46 AM
Mounting corner Bead KUIPORNG Remodeling 7 01-04-2007 08:20 AM
