How To Measure Window Jams? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-21-2009, 05:06 PM   #1
how to measure window jams?
How does a person get the size for window jams? The site Im on has two sizes,4 9/16 and 6 9/16. are these the only two sizes ever available? My house has the really old double hung from the 50s or 60s.( My house is 2x4) Thanks
fricandfrac is offline   Reply With Quote
Old 03-21-2009, 05:46 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
those sizes are for 2x4 or 2x6 with 1/2 sheathing and1/2 drywall
your probably dealing with 3/4 or thicker sheathing and maybe veneer plaster? no biggy just apply what you need to get the jambs flush to or a tiny bit proud to the inside wall
Tom Struble is offline   Reply With Quote
Old 03-21-2009, 06:18 PM   #3
Remodeling Contractor
you can measure this and order extension jams to be sure it fits exactly
Old 03-21-2009, 07:41 PM   #4
if you have an exterior door near by you can measure that jamb and that will tell you how thick your walls are.
II Weeks is offline   Reply With Quote
Old 03-23-2009, 05:46 PM   #5
Great thank you
Stool and Apron Window Trim Style Advice DIYCarp Carpentry 8 01-24-2009 09:31 AM
False Window craleo Remodeling 1 11-18-2008 08:44 PM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 10:00 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
