How To Measure Setbacks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-26-2013, 06:07 PM   #1
How to measure setbacks
Hello; I am building a garage in Los Angeles City. They told me to have a set back from the side property line and the back-lot property line.
The five- feet set back is measured from the inside portion of the wall
( not the center line of the wall) to the outside wall of the garage ?
Or... is it measured from the property line to the edge of the foundation ?
If the foundation is 16" wide and 16" deep, then it would mean that the measurement would be 8" away from the wall and toward the property line. Or... Is it measured from the property line to the roof overhang ?
Which means it is 12" from the wall and toward the property line.
When I start digging the foundation, where do I start ? Exactly five feet from the property line? or five feet less 8 inches ?
Gabriel8642 is offline   Reply With Quote
Old 07-26-2013, 06:18 PM   #2
Its easy for me to tell you what I think...three thousand miles away....so I can only tell you about the setback allowances here, and assume they are a universal guideline.
A setback is measured from the property line to the foundation of the structure in question
creeper is offline   Reply With Quote
Old 07-26-2013, 09:11 PM   #3
Rewards Points: 13,750
Going to have to go back and ask.
It's the same where I live as Creepers, but that does not matter, it's what your local area says.
Old 07-26-2013, 10:29 PM   #4
Rewards Points: 6,652
For my neighborhood, the setback is from the fence line that runs down the property line, to the outside wall of the garage. Of course, some properties, which now the new owners are fighting the next door neighbor, that has lived there for over 20 years, are trying to gain back their 2-5 feet that the old neighbor took over.
Basically go to your local AHJ (ie City hall or building planning office), or go to their website and all the info should be there. Also depending on their records online for taxing purposes, they may already have a image of the property, showing easements and setbacks, so may want to go to LA's website that you can find that info at, to see if anything is available there, since they will not open again until Monday morning, if they are not doing what they were doing three years ago, with the cutbacks, by running limited hours, and you had to almost throw a dart on a dartboard to find out if the office was open or not.
Old 07-27-2013, 07:10 AM   #5
joed's Avatar
Rewards Points: 12,922
It might measure to the edge of the roof(the part of the building closest to the property line). Best to go and ask the planning department of your city.
The Following 2 Users Say Thank You to joed For This Useful Post:
concretemasonry (07-27-2013), rjniles (07-28-2013)
Old 07-27-2013, 07:53 AM   #6
PoleCat's Avatar
Rewards Points: 1,646
In my neighborhood it is to any overhang or other projection greater than 12".
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
The Following User Says Thank You to PoleCat For This Useful Post:
Old 07-27-2013, 09:16 PM   #7
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
In California, you measure from the property line to the exterior face of your wall.
You may encroach into the set back up to 2' with the roof line but the area of the roof that encroaches must be of 1 hour fire rated construction.
Most places will allow even the walls to encroach but they will need to be 1 hr. fire rated construction also.
Andy.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
Old 07-29-2013, 10:12 AM   #8
Mold!! Let's kill it!
Rewards Points: 2,012
Around here it's "10 feet from the property line to a vertical line intersecting the nearest permanent portion of the structure." Underground usable space may not pass the same vertical line. No underground utility, pipe, wire, duct or accessory part of the structure may cross over the property line.
measure current to refrigerator tfox37380 Electrical 11 07-20-2012 08:43 PM
What is the MOST ACCURATE way to measure for replacement windows? Evil Scotsman General DIY Discussions 0 05-18-2010 10:06 PM
Suspended Ceiling - measure up or down? Woodcutter Remodeling 8 02-28-2009 05:53 AM
How to measure windows for new construction? pastrami Remodeling 1 04-26-2007 07:36 PM
