Old 06-03-2008, 03:09 PM   #1
How many stringers for 2x6" treads 5' long?
How many stringers do you suggest for a deck with 2x6" treads that are 5' long?
sandyman720 is offline   Reply With Quote
Old 06-03-2008, 03:17 PM   #2
Four.
jerryh3 is offline   Reply With Quote
Old 06-03-2008, 03:30 PM   #3
Makes sense. That would make then 15" oc.
I guess I should what thought of that before I asked such a dumb ? .
LOL thanks though!
Old 06-03-2008, 03:41 PM   #4
LOL thanks though!
It's better to get some opinions rather than second guess yourself after doing it. If you were going with 5/4 or composite, I think 12" centers would be more appropriate. Steps can take a lot of abuse.
Old 06-03-2008, 11:53 PM   #5
Custom Deck Builder
BuiltByMAC's Avatar
4 stringers supporting a 5' wide staircase would give you 20" o.c. -
0", 20", 40", 60"
That would work for wood 2x6 treads - if you're using composite, step up to 5 stringers -
0", 15", 30", 45", 60"
Think about using strongbacks if your staircase if longer than 10 treads.
Strongback = 2x6 glued and nailed to bottom edge of 2x12 stringer, should come up to junction of tread/riser cutout.
In the pic below, the strongback is the grey box. Install them on the sides of all your stringers and block between the stringers where each handrail post is attached.
Mac
BuiltByMAC is offline   Reply With Quote
installing stair treads. Wild Duk Flooring 4 05-20-2008 10:56 AM
Pennsylvania Bluestone Treads rjordan392 Building & Construction 4 03-30-2008 11:37 PM
Scribe Cutting Oak Stair Treads kcdave Carpentry 2 03-18-2008 08:13 PM
How long should A/C take to cool house? AllGoNoShow HVAC 2 06-17-2007 08:01 PM
