How Many Stair Stringers Do I Need? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-27-2010, 02:42 PM   #1
How many stair stringers do I need?
I'm building a short but wide staircase off the back of a new deck. The staircase will actually span 7'6". How many stringers will I need to support the treads of such a wide fence? I haven't been able to find this info online...
tom_matthews is offline   Reply With Quote
Old 07-27-2010, 03:14 PM   #2
Rewards Points: 5,336
I'd put one every 16".
Ron
Old 07-27-2010, 04:30 PM   #3
Old School
Willie T's Avatar
One of the few times I would agree with multiple stringers. In fact, I would even go with the stringers closer to a foot apart due to the probability that you may be using the same thin deck planks for the treads, and several people often traverse stairs together.
Willie T
Old 07-27-2010, 05:30 PM   #4
Registered User
Rewards Points: 526
If a composite--- go to their website, most require 12"o.c.
If wood, read it in here, page #17: http://www.lancova.com/deckinfo.pdf
Be safe, Gary
Cutting stair stringers for OLD basement steps 4just1don Building & Construction 1 08-11-2009 06:21 AM
Stair Stringers mntnvew Carpentry 14 04-14-2009 12:09 PM
Fastening stair stringers bacdef Carpentry 6 08-07-2008 09:31 PM
Holes in stair stringers wfischer Building & Construction 15 03-09-2008 09:21 AM
Installing floating engineered hardwood in entrance and stair stringers bluedisc22 Flooring 3 01-25-2008 02:03 PM
