How Many Holes Can I Drill Into A Wood Stud? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-26-2012, 08:00 PM   #1
How many holes can I drill into a wood stud?
Hello DIY Chatroom,
I am very new to the DIY scene. Im more of a computer kind of guy. Recently, I mounted three 23 monitors to wall studs (1 monitor per stud), but I went in blindly and the project came out looking different then I would have wanted it to look (the mounts are not level with eachother, and the result being monitors up to 2 higher then the other ones).
Each mount took up four 3/16 drill holes per stud. My main question is, will it ruin my wall if I make another four 3/16 holes per stud on the same stud, but in a different location (higher/lower)?
Thank you! Any help will make my week. Pictures are available if needed.
lostintyme is offline   Reply With Quote
Old 02-26-2012, 08:03 PM   #2
Rewards Points: 13,300
Not going to effect the studs at all.
lostintyme (02-26-2012)
Old 02-26-2012, 08:06 PM   #3
Thank you for the response! Just in case if this effects my situation, the holes are all 12" deep- this probably doesn't matter, but just in case.
Old 02-26-2012, 08:08 PM   #4
How did you drill a 12" deep hole in a stud that's most likly only 3 -1/2 deep?
Old 02-26-2012, 08:14 PM   #5
Whoops, it definitely was not 12", sorry. I must be getting tired. Thank you for the help!
Old 02-26-2012, 08:58 PM   #6
Old School
Willie T's Avatar
12" "Apart", maybe?
Franois Duc de La Rochefoucauld
Willie T
Old 02-27-2012, 08:51 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
a 3/16 hole wont affect the studs at all, if you were talking 1 - 3/16" yes as its just over 1/3 the overall width of the stud
woodworkbykirk is offline   Reply With Quote
Old 02-27-2012, 10:51 PM   #8
retired union carpenter
Send a message via Yahoo to coupe
the question is= can you locate a reasonable position for all 3 mounting brackets in line, in a way that uses same studs, keep level, and cover holes already made? all at once. are the holes in brackets located, so you can raise 3/4" or lower 3/4 and still cover top and bottom holes? measure down from ceiling for level and measure from closest inside corner for plumb lines. try to cover all holes before drilling more! the studs should be okay, as long as holes are 1/2-3/4 above or below other holes.
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-28-2012, 08:26 PM   #9
Rewards Points: 212
And 1-3/16 would be over 3/4 of the *thickness* of the studs, which would be the more relevant dimension if his walls are framed like most walls.
But yeah a couple of 3/16" holes aren't going to make any difference.
A Squared is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
ICF vs. Wood Framed JackOfAllTrades Building & Construction 31 11-01-2011 04:14 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 01:35 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Filling wood panel nail holes Sarah24 Painting 1 03-14-2008 01:48 PM
