How Many Flues Do I Need? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-01-2009, 11:33 AM   #1
How many flues do I need?
I am building a new house with a wood stove in the basement and a fireplace on the main floor. These units will sit directly on top of each other. Do I need a flue for each one? Can I use one flue with a series of dampers? I would appreciate any guidance.
Thanks!
Krystee is offline   Reply With Quote
Old 07-01-2009, 12:33 PM   #2
Concrete & Masonry
Rewards Points: 620
You will need one dedicated flue for the basement wood stove, running from basement floor to above roofline.
If the fireplace is going to be full masonry (not an insert running B vent, triple wall, etc..), that will also require it's own dedicated flue also.
No way to tie the 2 together, & it wouldn't be saving you much anyway, as flues are the cheapest part of the chimney/fireplace assembly.
jomama45 is offline   Reply With Quote
Old 07-01-2009, 01:44 PM   #3
fireplace
What is the best type of firebox to use, masonry?
Old 07-02-2009, 07:56 AM   #4
Concrete & Masonry
Rewards Points: 620
That's a fairly subjective question to answer, & depends on a few factors, money being the major one. As a mason, I'm obviously going to say a full masonry fireplace is the best. It's just not always the most realistic. If you're dead set on running a chimney up from the basement for a wood stove anyways, it might make sense to do a full masonry FP. Check out rumford dot com to see what I'm talking about.
chimney crown repair. gap between flues andy_b General DIY Discussions 4 02-19-2006 11:22 PM
