How Many Decking Boards Do I Need? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-20-2010, 10:33 AM   #1
how many decking boards do i need?
is there a way to come up with how many decking boards i need for my deck. ive used calculators online but they all give me something different. my deck is running 28ft along the house and it comes out 14ft from the house there is a 12x12 octagon on the same level connected to the deck. total demension of the deck is 31'6" x 17'6" at 417 square ft im using treated decking boards and my joist are 16" on center.i just want to be able to buy near the amount i need so i wont have to take alot back.
usc529 is offline   Reply With Quote
Old 02-20-2010, 10:52 AM   #2
It really depends on how you want to do your joints.
wnabcptrNH is offline   Reply With Quote
Old 02-20-2010, 10:53 AM   #3
Solutions (handyman)
Rewards Points: 364
Re Deck, I'd suggest you go to a Home Depot or whatever building supply store is close to you. Take your information and discuss this with them. Most stores of this kind have computer programs that will draw out you deck and provide the list of materials required. (Free service). To calculate on your own may be tricky because you'll want the deck planks to have staggering seams and you have to allow for short pieces, wastage and angle cuts.
Hope this helps
Mark Harvey is offline   Reply With Quote
Old 02-20-2010, 10:53 AM   #4
Rewards Points: 50
Personally I'd go with getting too many boards and taking back what you don't need.This allows you to be a lot more selective in discarding iffy lumber.It's also hard to calculate for waste, there could be a lot when cutting for an octogon.
daveb1 is offline   Reply With Quote
Old 02-20-2010, 10:57 AM   #5
jlhaslip's Avatar
Rewards Points: 2,882
is the octagon in addition to the main deck?
can you show us a sketch of the plan?
what material are you using? what widths? what spacing between them?
since you have not specified a length per board, we can't help you.
once you figure out the square footage, and convert it by adjusting for the board width and spacing, allow about 10 percent if the deck is 'square' and about 15 or 20 percent with the octagon shape to allow for angled waste cuts will be about right.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-20-2010, 11:33 AM   #6
im gonna use 5/4 x 6 x 16'
Old 02-20-2010, 11:54 AM   #7
jlhaslip's Avatar
5/4 by 6 is a nominal width of 6". finished width will be different.
What is the actual finished width? Here it would be 5 1/2" wide, so a foot of it covers only 5.5/12 = .4583333 square feet.
Actual Square footage / .458333 = Number of Lineal feet required.
Add a 15% cull/waste allowance and then divide by the board length to see the number of boards required.
Trex decking LL1 General DIY Discussions 56 09-30-2011 09:55 PM
how to lay my decking boards usc529 Building & Construction 4 02-13-2010 05:08 PM
Trex Decking over Treated Decking retired2pa General DIY Discussions 6 12-15-2009 06:16 PM
Old, spaced roof boards dangerous, bad, a deal breaker? jrdamien Roofing/Siding 2 01-06-2009 06:56 AM
hardwood flooring boards matjone Flooring 4 02-01-2008 05:35 PM
