How Many Deck Steps Before A Handrail Is Required? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-01-2014, 07:28 PM   #1
Rewards Points: 388
How many deck steps before a handrail is required?
Does anyone know the code for stair railings in NJ?
My deck is 22" above grade and has 2 steps going down (steps are 10' wide) . Looking at the deck, a hand railing may look odd because of how steep it will have to be to make the right angle. I don't even think it will feel functional at that angle.
I thought I read somewhere that railings were only required if the deck was greater than 30" above the ground and if there were 3 or more steps.
Can anyone confirm this?
Central New Jersey Area
adgjqetuo is offline   Reply With Quote
Old 05-01-2014, 08:17 PM   #2
funfool's Avatar
Rewards Points: 534
I do not know the code for your area, years ago, A railing was required if your deck was over 36" from grade. 30" sounds reasonable to me also.
But your 22" I do not think would be required from code.
Although, it would make it more convenient for some, to assist them walking up the 2 steps.
If you have a existing rail around the deck that a hand rail could butt into, I would install it.
I do not think the angle would look drastically funny, would be a great help for seniors or disabled persons to climb up.
Rarely used but a treat when available.
funfool is offline   Reply With Quote
The Following User Says Thank You to funfool For This Useful Post:
kwikfishron (05-01-2014)
Old 05-01-2014, 08:55 PM   #3
Rewards Points: 426
I'm a senior and I don't want to gain 22 inches in elevation going up or loose 22" in two steps going down. Make it 3 steps and my right knee might be able to handle it and the rail won't look strange.
SeniorSitizen is offline   Reply With Quote
Old 05-01-2014, 09:13 PM   #4
Rewards Points: 388
The rise is only 7.5" - 3 steps would be really shallow. My father has bad knee problems and he didn't seem to have trouble going up and down them.
Old 05-01-2014, 09:37 PM   #5
Rewards Points: 110
Not a bad riser height...but can the op confirm that the steps are ten FEET wide? If so, it is more like a cole of platforms as opposed to a set of stairs! That said, where I am 22" does not require a handrail regardless of widths. Ron
ront02769 is offline   Reply With Quote
Old 05-01-2014, 10:34 PM   #6
Rewards Points: 388
Yes, the stairs are 10 feet wide (centered on the 14 foot wide front end of the deck).
1 step down from the deck, followed by another step and then onto the ground.
I have 36" railings all around the deck but didn't know if I was required to actually go down the steps. I can always add it later, but for now if I'm not required by code, I didn't want to do it at this time.
Old 05-03-2014, 01:25 AM   #7
Registered User
Rewards Points: 4,914
NJ is probably under the Residential Deck Code; http://www.reedconstructiondata.com/...es/new-jersey/
http://www.awc.org/Publications/DCA/DCA6/DCA6-09.pdf
Gary
Old 05-04-2014, 12:16 PM   #8
Solutions (handyman)
Rewards Points: 362
railing
In my area and most, from what I have read, a deck below 24" does not require a railing. Having said that, the need may be there. If there are people who require assistance or support, put the railing on. It is just for the sake of safety and convenience. Some people are in need of a little extra when climbing stairs.
Mark Harvey is offline   Reply With Quote
Old 05-04-2014, 12:20 PM   #9
Rewards Points: 1,002
7 1/2" rises exceeds maximum in most places
Anti-wingnut is offline   Reply With Quote
Old 05-04-2014, 03:52 PM   #10
Rewards Points: 110
Max of 7 3/4", min of 4" is the standard around here. Ron
TREX decking extremely disappointing KHL General DIY Discussions 266 07-05-2013 12:26 PM
temporary exteriors steps until deck is built jrschneider9904 Building & Construction 13 10-04-2012 11:08 AM
handrail - 9 steps up Keith Lumsden Carpentry 7 07-08-2012 01:35 PM
deck header over concrete steps and other deck questions bobcatnj Building & Construction 6 05-09-2008 03:54 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
